@All, I had the same issue where the Mac was not able to ping the dex.local, and VNC client cannot connect and all sort of issues. I change to static IP address the raspberry and the issues continued. I had the image on the SD card “Rasbian for robots” 2015.11.09. I decided to reload a new Debian OS to a new SD card (32GB this time), with my own microsd card adapter following this instructions: http://www.dexterindustries.com/howto/install-raspbian-for-robots-image-on-an-sd-card/
- I downloaded the latest OS from here: https://sourceforge.net/projects/dexterindustriesraspbianflavor/à
from 2016.01.05. - I used Suffit Expander to unzip the zip
getting the .img file - I used this command line to copy the img to the sd card: sudo dd bs=1m if=2015.11.09_Dexter_Industries_wheezy.img of=/dev/rdisk2
You have to use rdisk if you are using El Capitan OS on the Mac.
Where 2 is the number of your own card reader (could be 3 or 4), NEVER USE 1
took 15 minutes to copy the image - moved back the microsd card in the pi, and booted, and now evrerything work property from bonjour dex reconition, ping dex.local, vnc…
@John: you may want to look into your microsd card and microsd card reader quality. It seems that there are a lot of corrupted ones, and the card reader was very bad, like the lock not staying in place, and had bad contacts.
