GoPiGo3
Upgraded to Dexter OS Ver 2.1.1
The usb drive is no longer recognized, cannot save files from Bloxer menu.
And photos from the camera are not saved.
Tried reformatting Windows 10: FAT32 with drive name GPG1 (no spaces)
Same results.
Switching back to the Ver 1.1.1 SD card, the same usb drive did work to upgrade to Ver 1.3
It also works to save files.
Do you have any other USB drives around to test with?
The best way to see if the drive gets detected is to head to Jupyterlab’s interface and check if there’s a drive in the side panel if you’re on DexterOS 2.x (make sure to click on the refresh button in the side panel) or use the web terminal on DexterOS 1.x to check if there’s a drive in /media directory.
Different usb drive fixed it, now works both in 1.3 & 2.1
Remains strange that the black Dexter usb drive will work in 1.3 & not 2.1
But not important
