Hi all,
I am new to the GoPiGo. After the assembly is done, I inserted the sd card supplied by Dexter Industries. When I ssh into raspberry from my ubuntu machine with the ethernet cable, it gave an error connection refused. Here is the output of ssh:
cheok@ThinkPad-X240:~ ssh -vvv pi@192.168.1.51 OpenSSH_6.6.1, OpenSSL 1.0.1f 6 Jan 2014 debug1: Reading configuration data /etc/ssh/ssh_config debug1: /etc/ssh/ssh_config line 19: Applying options for * debug2: ssh_connect: needpriv 0 debug1: Connecting to 192.168.1.51 [192.168.1.51] port 22. debug1: connect to address 192.168.1.51 port 22: Connection refused ssh: connect to host 192.168.1.51 port 22: Connection refused cheok@ThinkPad-X240:~
I have enabled ssh on the raspberry and i can ping it:
cheok@ThinkPad-X240:~ ping 192.168.1.51 PING 192.168.1.51 (192.168.1.51) 56(84) bytes of data. 64 bytes from 192.168.1.51: icmp_seq=1 ttl=64 time=0.049 ms 64 bytes from 192.168.1.51: icmp_seq=2 ttl=64 time=0.030 ms 64 bytes from 192.168.1.51: icmp_seq=3 ttl=64 time=0.066 ms 64 bytes from 192.168.1.51: icmp_seq=4 ttl=64 time=0.067 ms 64 bytes from 192.168.1.51: icmp_seq=5 ttl=64 time=0.061 ms 64 bytes from 192.168.1.51: icmp_seq=6 ttl=64 time=0.035 ms 64 bytes from 192.168.1.51: icmp_seq=7 ttl=64 time=0.039 ms 64 bytes from 192.168.1.51: icmp_seq=8 ttl=64 time=0.066 ms 64 bytes from 192.168.1.51: icmp_seq=9 ttl=64 time=0.069 ms 64 bytes from 192.168.1.51: icmp_seq=10 ttl=64 time=0.066 ms ^C --- 192.168.1.51 ping statistics --- 10 packets transmitted, 10 received, 0% packet loss, time 8999ms rtt min/avg/max/mdev = 0.030/0.054/0.069/0.017 ms cheok@ThinkPad-X240:~
Please advice.
Anthony
