ok, your test is a different one, I am running GPIO r/w under multithreading and multitasking conditions.
Single pin read/write by wiringPi or pigpio is even much faster by C
(pigpio: <10 ns ! that’s >= 100 MHz ! almost 1000x quicker than Python!).
But my test is running GPIO r/w under high cpu load by multiple threads and tasks running simultaneously, and even then it’s at <= 180ns for r/w 4 different GPIOs simultaneously plus parallel tasks, which is 10-20MHz for 2 parallel GPIO r/w threads, so still 100x faster than Python by single-toggling.
Of course, “real-time” always depends on the current application. But IMO 180ns even at high cpu load is extremely good for real-time capability.
edit:
can you port my C code 1:1 to Python?
I am really curious how quick Python would perform under multithreading and multitasking conditions.
edit2, just tested:
by 5 parallel tasks even read/write of 10 different GPIOs is possible at exactly the same time:
125ns for toggling all the 10 GPIOs, so still 100% real-time capable!
/* Program GPIO test
* Raspberry Pi 2
* ver 003
#include <stdio.h>
#include <stdlib.h>
#include <unistd.h>
#include <math.h>
#include <fcntl.h>
#include <string.h>
#include <sys/ioctl.h>
#include <stdint.h>
#include <sys/time.h>
#include <errno.h>
#include <pthread.h>
#include <wiringPi.h>
#include <wiringSerial.h>
#include <wiringPiI2C.h>
#include <softPwm.h>
// tasks
unsigned long itime0, xtime0, itime1, xtime1, itime2, xtime2, itime3, xtime3, itime4, xtime4;
int s0=1, s1=1, s2=1, s3=1, s4=1;
int counts = 1000000;
void* thread0 (void* ) { //
volatile int ival;
itime0=millis();
for (int i=0; i<counts; i++) {
ival=digitalRead(5);
digitalWrite(20, HIGH);
digitalWrite(20, LOW);
xtime0=millis();
s0=0;
return NULL;
void* thread1 (void* ) { //
volatile int ival;
itime1=millis();
ival=digitalRead(6);
digitalWrite(21, HIGH);
digitalWrite(21, LOW);
xtime1=millis();
s1=0;
return NULL;
void* thread2 (void* ) { //
volatile int ival;
itime2=millis();
ival=digitalRead(17);
digitalWrite(22, HIGH);
digitalWrite(22, LOW);
xtime2=millis();
s2=0;
return NULL;
void* thread3 (void* ) { //
volatile int ival;
itime3=millis();
ival=digitalRead(18);
digitalWrite(23, HIGH);
digitalWrite(23, LOW);
xtime3=millis();
s3=0;
return NULL;
void* thread4 (void* ) { //
volatile int ival;
itime4=millis();
ival=digitalRead(19);
digitalWrite(24, HIGH);
digitalWrite(24, LOW);
xtime4=millis();
s4=0;
return NULL;
void setupwiringPi() {
int iores;
putenv ("WIRINGPI_GPIOMEM=1"); // no sudo for gpios required
iores = wiringPiSetupGpio(); // init by GPIO pin numbering
if( iores == -1 ) exit(1);
pinMode( 5, INPUT); pullUpDnControl( 5, PUD_UP);
pinMode( 6, INPUT); pullUpDnControl( 6, PUD_UP);
pinMode( 17, INPUT); pullUpDnControl(17, PUD_UP);
pinMode( 18, INPUT); pullUpDnControl(18, PUD_UP);
pinMode( 19, INPUT); pullUpDnControl(19, PUD_UP);
pinMode( 20, OUTPUT);
pinMode( 21, OUTPUT);
pinMode( 22, OUTPUT);
pinMode( 23, OUTPUT);
pinMode( 24, OUTPUT);
// main
int main() {
int key;
unsigned long t=0, t0, t1, t2, t3, t4;
double ns0, ns1, ns2, ns3, ns4;
sleep(1);
setupwiringPi();
pthread_t tid0, tid1, tid2, tid3, tid4;
struct sched_param param;
pthread_create(&tid0, NULL, thread0, NULL); //
param.sched_priority = 80;
pthread_setschedparam(tid0, SCHED_RR, ¶m);
pthread_create(&tid1, NULL, thread1, NULL); //
param.sched_priority = 60;
pthread_setschedparam(tid1, SCHED_RR, ¶m);
pthread_create(&tid2, NULL, thread2, NULL); //
param.sched_priority = 40;
pthread_setschedparam(tid2, SCHED_RR, ¶m);
pthread_create(&tid3, NULL, thread3, NULL); //
param.sched_priority = 20;
pthread_setschedparam(tid3, SCHED_RR, ¶m);
pthread_create(&tid4, NULL, thread4, NULL); //
param.sched_priority = 10;
pthread_setschedparam(tid4, SCHED_RR, ¶m);
while( s0 || s1 || s2 || s3 || s4) {
printf("%ld\n", t);
delay(100);
t+=100;
// wait for threads to join before exiting
pthread_join( tid0, NULL);
pthread_join( tid1, NULL);
pthread_join( tid2, NULL);
pthread_join( tid3, NULL);
pthread_join( tid4, NULL);
printf("\n\n");
t0=xtime0-itime0;
t1=xtime1-itime1;
t2=xtime2-itime2;
t3=xtime3-itime3;
t4=xtime4-itime4;
ns0=t0*1000000/(float)(4*counts);
ns1=t1*1000000/(float)(4*counts);
ns2=t2*1000000/(float)(4*counts);
ns3=t3*1000000/(float)(4*counts);
ns4=t4*1000000/(float)(4*counts);
printf("time thread0: %ld ms, time thread1: %ld ms\n", t0, t1);
printf("time thread2: %ld ms, time thread3: %ld ms\n", t2, t3);
printf("time thread4: %ld ms \n\n", t4);
printf("time delta0: %.1f ns, time delta1: %.1f ns\n", ns0, ns1);
printf("time delta2: %.1f ns, time delta3: %.1f ns\n", ns2, ns3);
printf("time delta4: %.1f ns \n\n", ns4);
key=getchar();
exit(0);
