admin1
May 23, 2015, 9:58am
#1
Hello Forum!
I want to stream what the picam capture while i control the GoPiGo with “w” “a” “s” “d” as the script provided “basic_test_all.py”.
In order to the streaming video i wrote this little code and it works:
import all the libraries needed
h=200
w=300
camera = PiCamera()
camera.resolution(w,h)
camera.framerate = 5
rawCapture = PiRGBArray(camera, size(w,h))
time.sleep(0.1)
from frame in camera.capture_continuous (rawCapture, format"bgr", use_video_port=True):
image_RGB = frame.array
cv2.imshow("Image", image_RGB)
key = cv2.waitKey(1) & 0xFF
rawCapture.truncate(0)
if key == ord("q"):
break
With this code, where and how would you put the:
print "nCmd:",
a = raw_input()
if a=='w':
fwd()
elif a=='a':
left()
elif a=='d':
right()
elif a=='s':
bwd()
elif a=='x':
stop()
in order to work at the same time?
Thanks a bunch again!
karan
May 24, 2015, 11:49pm
#2
To make them work at the same time, you can either have 2 different programs running in 2 sessions via VNC or SSH or you can have a single program with multiple threads. It would be hard to get it to work without threads in a single program.
Sorry, but i’m a noob and i don’t know what you mean by threads. Is there an easy way to get all this stuff running into one script ?
Thanks again karan!
exadon
May 25, 2015, 10:59am
#4
check out this link here :Python Multithreaded Programming .
Running several threads is similar to running several different programs concurrently
Thanks Exadon!
I’ve been testing some examples, and i understand how it works (more or less). On the scripts i wrote, It seems that only works one thread.
So, I own a Raspberry pi B+, can i deal with threading codes whit the B+ ? or should i upgrade to Raspberry pi 2 in order to send two programs by two different threads just to run them in parallel ?
Seriously, thank you very much!
exadon
May 25, 2015, 6:06pm
#6
You are fine with any model of the raspberry pi.
Well, I’ve been trying some examples but i can only execute one program.
I wrote this code:
import threading
class prog(threading.Thread):
def __init__(self):
threading.Thread.__init__(self)
def run(self):
print "First program"
class prog2(threading.Thread):
def run(self):
print “Second program”
my_program1=prog()
my_program2=prog2()
my_program1.start()
my_program2.start()
And… with this code i get all the time: “First program”
So if you please, can tell me why the second program isn’t running, i’ll be grateful.
Thanks a bunch!
karan
May 27, 2015, 3:36am
#8
Stackoverflow might be a better place to look for answers around threading. I am not sure what the problem is exactly but there will be a lot of good posts on stackoverflow to get you started with threading like this: http://stackoverflow.com/questions/2846653/python-multithreading-for-dummies .
