Greetings!
I have discovered that in the 2.2.2 version of DexterOS, there does not appear to be a way to cut-and-paste between programs - or to merge one program with another.
In my example, I created a simple “distance sensor” test. I also created a simple test routine for the newly installed bumper. What I want to do now is merge the “bumper” code into the routine for the distance sensor so that the distance sensor code is also sensitive to bumper impact.
Unfortunately - insofar as I can tell - I cannot cut-and-paste between programs. Neither have I discovered a way to save a code snippet and import into an existing program.
Would you please consider adding a feature that allows this in a future release?
Respectfully submitted,
Jim “JR”
