mattallen37 wrote:
FYI, even though the EV3 touch sensor is analog, it uses pin 6 (instead of pin 1).Does this mean that using the EV3 touch sensor with BrickPi only requires rewiring? In that case a simple adapter might work.
With regard to the other sensors I wonder if it would be possible to connect the RPi to an Arduino Mega 2560 board using USB. I’m not very experienced with electronics, but what I read from that board’s specs it has 4 HW UARTS (one used for the USB connection), so 3 free for sensors. As zencuke pointed out now that Lego has released the EV3 source code, with details of the serial protocol in the d_uart_mod.c file, it might be possible to write firmware for the Mega 2560 to handle the EV3 sensors. If this is possible it could be a nice extension of the BrickPi project. What do you think?
