After reading posts like Temperature&humidity sensor (High Accuracy&Mini) v1.0 Bad readings
And much Googling I fixed python script /home/pi/Dexter/GrovePi/Software/Python/grove_i2c_temp_hum_sensor_mini/grove_i2c_temp_hum_mini.py
With this script I get correct temp and hum values! And all working fine.
#!/usr/bin/env python
# GrovePi Library for using the Grove - Temperature&Humidity Sensor (http://www.seeedstudio.com/depot/Grove-TemperatureHumidity-Sensor-HighAccuracy-Mini-p-1921.html)
# The GrovePi connects the Raspberry Pi and Grove sensors. You can learn more about GrovePi here: http://www.dexterindustries.com/GrovePi
# Have a question about this library? Ask on the forums here: http://forum.dexterindustries.com/c/grovepi
# Released under the MIT license (http://choosealicense.com/licenses/mit/).
# For more information see https://github.com/DexterInd/GrovePi/blob/master/LICENSE
# NOTE:
# The software for this sensor is still in development and might make your GrovePi unuable as long as this sensor is connected with the GrovePi
import time,sys
import RPi.GPIO as GPIO
import smbus
debug = 0
# use the bus that matches your raspi version
rev = GPIO.RPI_REVISION
if rev == 2 or rev == 3:
bus = smbus.SMBus(1)
else:
bus = smbus.SMBus(0)
class th02:
ADDRESS = 0x40
TH02_REG_STATUS = 0x00
TH02_REG_DATA_H = 0x01
TH02_REG_DATA_L = 0x02
TH02_REG_CONFIG = 0x03
TH02_REG_ID = 0x11
TH02_STATUS_RDY_MASK = 0x01
TH02_CMD_MEASURE_HUMI = [0x01]
TH02_CMD_MEASURE_TEMP = [0x11]
SUCCESS = 0
def getTemperature(self):
bus.write_i2c_block_data(self.ADDRESS, self.TH02_REG_CONFIG, self.TH02_CMD_MEASURE_TEMP)
for i in range(0,100):
status=self.getStatus()
if debug:
print("st_temp:",status)
if i == 99:
print("can't get response for Temp command for 99 retries:")
exit()
if status:
break
time.sleep(.5)
t_raw_h=bus.read_byte_data(self.ADDRESS, self.TH02_REG_DATA_H)
t_raw_l=bus.read_byte_data(self.ADDRESS, self.TH02_REG_DATA_L)
if debug:
print("raw_temp:",t_raw_h)
print("raw2_temp:",t_raw_l)
temperature = t_raw_h<<8
#print("temp1",temperature)
temperature |= t_raw_l
#print("temp2",temperature)
temperature >>= 2
#print("temp3",temperature)
return (temperature/32.0)-50.0
def getHumidity(self):
bus.write_i2c_block_data(self.ADDRESS, self.TH02_REG_CONFIG, self.TH02_CMD_MEASURE_HUMI)
if debug:
print("st:",status)
if i == 99:
print("can't get response for Hum command for 99 retries:")
exit()
if status:
break
time.sleep(.5)
if debug:
print(t_raw)
humidity = t_raw_h<<8
#print("humidity1",humidity)
humidity |= t_raw_l
#print("humidity2",humidity)
humidity >>= 4
#print("humidity3",humidity)
return (humidity/16.0)-24.0
def getStatus(self):
status=bus.read_i2c_block_data(self.ADDRESS, self.TH02_REG_STATUS,1)
#if debug:
# print(status)
if status[0] & self.TH02_STATUS_RDY_MASK != 1:
return 1
else:
return 0
if __name__ == "__main__":
t= th02()
print(t.getTemperature(),t.getHumidity())
time.sleep(2)
