i have a problem with the go pi go on not being able to connect it to my mac. i have check every thing per your instruction on the website but it still does not connect. the usb ethereal cable said that it is connected but when i went to the terminal and type in <ping dex.local> ,the msg shows <ping: cannot resolve dex.local: Unknown host>.
I just want to confirm: you’ve powered up the Pi, connected it to your mac directly over ethernet. The ACT and PWR lights on the Raspberry Pi are on, and the ACT light blinks. The LED’s on the ethernet port light up. Can you confirm this is all true?
If that’s true, and you can’t ping dex.local, there are a few things we can try:
1). Turn wifi on your macbook off, and remove the wifi usb adapter on your Raspberry Pi. Give it a minute, and then try to ping again.
2). Install a program called “Bonjour Browser”, this is available for Mac here: http://www.tildesoft.com/ There is a ling for download at the bottom of the page. You should install this, run it, and click “Reload Services” This should search the network (ethernet) to find all services on your network, you should see “dex” on there.
Alternatively you can connect to the ip address of the GoPiGo by opening a browser window on your Mac and entering the ip address of the GoPiGo and hitting Enter. This will open the web page on the Pi and give you a choice to open the VNC interface or the Terminal interface.
Before we get too far off on this thread; bunkisland we’re helping you on a different thread. go pi go 1234, still waiting to hear back about our questions.
Do the power light and ACT blink at all when you turn the Raspberry Pi on. Can you insert the SD card in your computer and tell us what you see there. Does the SD card show up empty or with some data.
Also as a followup to Karan’s question: for the purpose of connecting to the Pi, we recommend using a 2A power supply such as the Raspberry Pi power supply.
now when i try to ping the ip address it worked but now a new problem came out when i go to my chrome web browser and enter dex local/ it did not worked
i even considered static ip and it worked but the problem is when i go to my browser and type in dex.local it did not work.BTW i am in singapore not US would it make a diffrence?
