Ref: The following:
I note that all of this is done as the standard user.
Shouldn’t this be done as root as it installs stuff all over the place?
Update:
After installing the sensors packages, I get the following:
Removing "di_sensors" and "line_follower" to make space for new ones
running install
running bdist_egg
running egg_info
creating DI_Sensors.egg-info
writing requirements to DI_Sensors.egg-info/requires.txt
writing DI_Sensors.egg-info/PKG-INFO
writing top-level names to DI_Sensors.egg-info/top_level.txt
writing dependency_links to DI_Sensors.egg-info/dependency_links.txt
writing manifest file 'DI_Sensors.egg-info/SOURCES.txt'
reading manifest file 'DI_Sensors.egg-info/SOURCES.txt'
installing library code to build/bdist.linux-armv7l/egg
running install_lib
running build_py
[. . . lots of stuff . . .]
Using /usr/local/lib/python3.7/dist-packages/python_periphery-2.3.0-py3.7.egg
Finished processing dependencies for Line-Follower==1.0.0
Configuring the red line follower in DI_Sensors installation
Done configuring the red line follower in DI_Sensors installation
The red line follower was depreciated centuries ago, how do I get the black line follower back?
