The New GoPiGo3 Install - Anyone else testing?
I’ve been testing the new GoPiGo3 install options over PiOS Trixie Desktop and Lite, and found Option A fully working.
Option B on PiOS Trixie Lite still has a minor issue configuring I2C, but the fix will be very simple for CleoQC to implement.
One of the changes in the new GoPiGo3 install is moving the list_of_serial_numbers (that have 16 tick motors) and the gpg3_config.json file that maintains the robot specifics, to the user’s $HOME instead of under /home/pi/GoPiGo3.
For Python users this change is transparent, but new users using Option B and wishing to program the GoPiGo3 in C++, the GoPiGo3 C++ API is still looking under /home/pi/GoPiGo3. Additionally, the C++ compiler is now version 14.2 which is stricter about some language constructs.
I am working to bring the C++ GoPiGo3 API and Examples to work with the new config files location and the new C++ compiler.
myrobot.cpp linked with libgopigo3_cpp.a:
(.venv) tovli@mrgpg3:~/MRGPG3/systests/cpp/gopigo3proj $ build/bin/myrobot
**** GoPiGo3 Robot Constants:
 - WHEEL_DIAMETER: 66.500 mm
 - WHEEL_BASE_WIDTH: 117.000 mm
 - ENCODER_TICKS_PER_ROTATION: 6   <<---WRONG because of new install config files location
 - MOTOR_GEAR_RATIO: 120
 - SPEED: 150
        fwd w                  r reset encoders
 left  a  spin s   d  right
            bkwd x
                               spacebar  STOP
encoders: (0, 0) Cmd: (q to exit): w
LEFT : motor_state: 0,  pwr: -128,  pos: 0,  dps: 0
RIGHT: motor_state: 0,  pwr: -128,  pos: 0,  dps: 0
encoders: (0, 0) Cmd: (q to exit):  stopping..
LEFT : motor_state: 0,  pwr: 2,  pos: 524,  dps: 0
RIGHT: motor_state: 0,  pwr: 12,  pos: 521,  dps: 0
encoders: (524, 521) Cmd: (q to exit): q
Interestingly, when I went to make a pull request for my fix, I discovered that the GoPiGo3 C++ API did have the new files location modification already coded. I’m not sure how I ended up not realizing the Option B install had changed the C++ GoPiGo3 API code, but this was great news.
Problem solved - I copied the changed C++ files to my systests/cpp/gopigo3proj project and ENCODER_TICKS_PER_ROTATION was properly set to 16 on GoPiGo3 Dave.
(Then I noticed more problems to be solved …)
Not yet,I just returned. However in about a month we’ll get another user.
