Trouble reading GrovePi sensors
Hi, I’ve installed grove.py into my raspberry pi, then run “cd home/pi.grove.py”, followed by “grove_” and TAB, confirmed the sensor reading options are there.
I have then run grove_moisture_sensor and am getting the error “Check whether I2C enabled and Grove Base Hat RPi or Grove Base Hat RPi Zero inserted”.
I have tried changing the I2C address in the adc.py file (found in home/pi/grove.py/grove), and this hasnt worked
Please help
Hello!
It looks like the forum community could be stumped on this problem. Could you forward your details and a list of which GrovePi Sensors you are using to support@modrobotics.com?
Our team should be able to help. Let me know if you have any questions,
And @mitch.kremm, please post results here so the rest of us can learn too.
