I updated my robot last week and was able to program on it and do logging etc. However, since then I am unable to do any programming. I have re-installed the update a couple of times, and I see the wi-fi and can connect to it. However, I cannot go to mygopigo.com or 10.10.10.10.
I’ve tried four times to update from 1.2 to 1.3.2 Each went through without a glitch, so it has been no help.
Are you getting logs on a usb drive? I’d be interested in seeing the logs that are System logs.
Lisa will probably share this with you but in case you read this before talking with her.
Can you find an SD card that has a native 1.3.2 on it? Directly from the image, not one that has been upgraded to 1.3.2.
Can you boot up the non-working robot with that SD card? I believe it will fix the robot. If it doesn’t, I would need the System log from this attempt.
If it works fine with that SD card, do a shutdown, swap the card to the previous, non working one, and boot up again.
I will be able to find an SD card in Boston tomorrow. All the robots in HEAF are having the same issue. The class couldn’t happen today because of this.
@lagnihotr
I’m really sorry to hear that about the class. My apologies.
I tried really hard to reproduce it to understand what’s happening, and have not been able to get the problem to happen. Yet there is a problem for sure if all your robots have the issue (even if only one did).
So I got a copy of the data on their SD card and just loaded it up on my machine… Didn’t work It didn’t want to copy “overlays” into my sd card. Going to HEAF tomorrow and they have a brand new rover. I will put that SD card in mine and see what happens…
