Hello everyone. Picked up a gopigo and am enjoying it thus far. Im particularly interested in the Browser streaming robot but I have some technical questions. I am rather new to Python programming so go easy on me! What Im trying to achieve here is to substitute the GOPIGO board to just use a L298N board to drive motors. I will eventually be using a second L298N and an arduino. I tinkered with the code a bit but was unsuccessful, I noticed on my terminal I get a ( IOerror ) which according to the motor controller.py is linked to the gopigo board somehow. Can anyone guide me a bit in order to just control 4 output pins from the Browser robot ?
Also, Im sure its an easy switch but I cant find it online, how can I switch to my USB camera instead of the Pi cam? I eventually would like to be able to switch from 2 different cameras in the future.
Thank you so much! I managed to get the controls to work with my L298N board. I appreciate it. I am still working on the USB cam but have not been so lucky yet.
I noticed, this code however only has 1 joystick ? I tried to backtrack the original code so that I can still have 2 joysticks. Ideally 1 would be for movement ( as it currently is ) and the second is to control an arm, the arm is not servo driven, it will be driven the same method as with the L298N.
