I got my GrovePi today. So I set it up with my raspberry pi. I had installed Raspbian 8 (jessie) on this one. So I cloned the GrovePi git repo from github.
If i run the grove_firmware_version_check.py script from Software/Python. I get the response, that GrovePi has version 1.2.2 installed. So it looks like the connection to the board works.
The next step was that I get data from the uv sensor, which I also ordered.
I got this one: http://www.seeedstudio.com/wiki/Grove_-_UV_Sensor
So I connected the sensor to the A0 connector and wrote a little test python script. But I think I get the wrong data.
My script looks like this:
import grovepi
import time
sensor = 0
grovepi.pinMode(sensor, "INPUT")
try:
analog_value = grovepi.analogRead(sensor)
print("Sensor Value: ", analog_value)
time.sleep(.5)
except IOError:
print("Error")
If I run this script I get values between 58 and 62. But I don’t this this is correct. If I totally disconnect the sensor and run the script I get values between 105 and 109. Shouldn’t this be 0 than? Or is there something wrong?
