ssh working… but VNC not connecting (used realvnc and gtk vnc viewer)
Is there anything to start on the board
If you are using the Dexter Industries SD card, the VNC should be running by default. You can try running vncserver :1 to start a new VNC server on the Pi.
On the client side, we have tested VNC Viewer. Use the IP address you have or raspberrypi.local:1 as the address in the VNC client.
Let us know if this helps.
That works.Thanks
