I have the apparently unsupported Dexter Industries WIFI module.
I downloaded the example Websockets files linked at the bottom: http://www.dexterindustries.com/manual/ … b-browser/
I opened up DIWIFI-Websocket-Chrome.c and DIWIFI-Websocket-Chrome.h, hit Compile Program and got 71 errors.
File "C:UsersPersonDocumentsRoboticsProgramsDIWIFI-Websocket-Chrome.c" compiled on Jan 14 2015 19:17:36
*Warning*:Substituting similar variable 'playSound' for 'PlaySound'. Check spelling and letter case.
*Warning*:Substituting similar variable 'stopAllTasks' for 'StopAllTasks'. Check spelling and letter case.
*Warning*:Substituting similar variable 'stringFind' for 'StringFind'. Check spelling and letter case.
**Error**:'*' Indirection levels mismatch. Call to 'nxtWriteRawHS'. Parameter: 'char * pData' is 'byteData' of type 'ubyte'.
**Error**:'*' Indirection levels mismatch. Call to 'nxtWriteRawHS'. Parameter: 'char * pData' is 'newline' of type 'ubyte'.
**Error**:Expression does not fit parameter. Call to 'nxtWriteRawHS'. Parameter: 'char * pData' is 'newline' of type 'ubyte [2]'.
**Error**:'*' Indirection levels mismatch. Call to 'memset'. Parameter: 'void * pToBuffer' is 'buff[0]' of type 'ubyte'.
**Error**:'*' Indirection levels mismatch. Call to 'memcpy'. Parameter: 'void * pToBuffer' is 'buff[0]' of type 'ubyte'.
*Warning*:Substituting similar variable 'stringFromChars' for 'StringFromChars'. Check spelling and letter case.
**Error**:Procedure call Parameters don't match declaration for 'stringFromChars(unsigned string & sToString, char * pFromChars)'
**Error**:'*' Indirection levels mismatch. Call to 'nxtWriteRawHS'. Parameter: 'char * pData' is 'pData' of type 'ubyte &'.
**Error**:'*' Indirection levels mismatch. Call to 'memcpy'. Parameter: 'void * pToBuffer' is 'buf[index]' of type 'ubyte'.
**Error**:'*' Indirection levels mismatch. Call to 'nxtReadRawHS'. Parameter: 'ubyte * pData' is 'BytesRead[0]' of type 'ubyte'.
**Error**:'const' expressions does not fit. Call to 'find_and_print'. Parameter: 'unsigned string & findme' is '"WebSocket-Key: "' of type 'string'.
*Warning*:Symbol 'nxtDisplayString' is 'deprecated' definition. There may be alternate symbol with equivalent functionality.
**Error**:'const' expressions does not fit. Call to 'writeStr'. Parameter: 'unsigned string & sData' is '"AT+DNSLOOKUP="' of type 'string'.
**Error**:'const' expressions does not fit. Call to 'writeStr'. Parameter: 'unsigned string & sData' is '"www."' of type 'string'.
**Error**:'const' expressions does not fit. Call to 'writeStr'. Parameter: 'unsigned string & sData' is '"dexterindustries"' of type 'string'.
**Error**:'const' expressions does not fit. Call to 'writeStr'. Parameter: 'unsigned string & sData' is '".com"' of type 'string'.
**Error**:'const' expressions does not fit. Call to 'writeStr'. Parameter: 'unsigned string & sData' is '"AT+NCTCP="' of type 'string'.
**Error**:Expression does not fit parameter. Call to 'nxtWriteRawHS'. Parameter: 'char * pData' is 'byteStart2' of type 'ubyte [3]'.
**Error**:'const' expressions does not fit. Call to 'writeStr'. Parameter: 'unsigned string & sData' is '"GET "' of type 'string'.
**Error**:'const' expressions does not fit. Call to 'writeStr'. Parameter: 'unsigned string & sData' is '"http://"' of type 'string'.
**Error**:'const' expressions does not fit. Call to 'writeStr'. Parameter: 'unsigned string & sData' is '"dexterindustries."' of type 'string'.
**Error**:'const' expressions does not fit. Call to 'writeStr'. Parameter: 'unsigned string & sData' is '"com"' of type 'string'.
**Error**:'const' expressions does not fit. Call to 'writeStr'. Parameter: 'unsigned string & sData' is '"/websocket/"' of type 'string'.
**Error**:'const' expressions does not fit. Call to 'writeStr'. Parameter: 'unsigned string & sData' is '"calc2.php"' of type 'string'.
**Error**:'const' expressions does not fit. Call to 'writeStr'. Parameter: 'unsigned string & sData' is '"?"' of type 'string'.
**Error**:'const' expressions does not fit. Call to 'writeStr'. Parameter: 'unsigned string & sData' is '"name="' of type 'string'.
**Error**:'const' expressions does not fit. Call to 'writeStr'. Parameter: 'unsigned string & sData' is '" HTTP"' of type 'string'.
**Error**:'const' expressions does not fit. Call to 'writeStr'. Parameter: 'unsigned string & sData' is '"/1.1"' of type 'string'.
**Error**:'const' expressions does not fit. Call to 'writeStr'. Parameter: 'unsigned string & sData' is '"Host: "' of type 'string'.
**Error**:Expression does not fit parameter. Call to 'nxtWriteRawHS'. Parameter: 'char * pData' is 'byteEnd' of type 'ubyte [3]'.
**Error**:Array size mismatch. Call to 'memset'. Parameter: 'const char nValue' is 'websocketBuff' of type 'ubyte [128]'.
**Error**:'*' Indirection levels mismatch. Call to 'nxtWriteRawHS'. Parameter: 'char * pData' is 'nData[i]' of type 'ubyte'.
**Error**:Array size mismatch. Call to 'appendToBuff'. Parameter: 'const ubyte & pData' is 'listen_cmd' of type 'ubyte [11]'.
**Error**:Array size mismatch. Call to 'appendToBuff'. Parameter: 'const ubyte & pData' is 'newline' of type 'ubyte [1]'.
**Error**:Expression does not fit parameter. Call to 'nxtWriteRawHS'. Parameter: 'char * pData' is 'byteStart' of type 'ubyte [3]'.
**Error**:'const' expressions does not fit. Call to 'writeStr'. Parameter: 'unsigned string & sData' is '"HTTP/1.1 101 "' of type 'string'.
**Error**:'const' expressions does not fit. Call to 'writeStr'. Parameter: 'unsigned string & sData' is '"Switching "' of type 'string'.
**Error**:'const' expressions does not fit. Call to 'writeStr'. Parameter: 'unsigned string & sData' is '"Protocols"' of type 'string'.
**Error**:'const' expressions does not fit. Call to 'writeStr'. Parameter: 'unsigned string & sData' is '"Upgrade: "' of type 'string'.
**Error**:'const' expressions does not fit. Call to 'writeStr'. Parameter: 'unsigned string & sData' is '"websocket"' of type 'string'.
**Error**:'const' expressions does not fit. Call to 'writeStr'. Parameter: 'unsigned string & sData' is '"Connection: "' of type 'string'.
**Error**:'const' expressions does not fit. Call to 'writeStr'. Parameter: 'unsigned string & sData' is '"Upgrade"' of type 'string'.
**Error**:'const' expressions does not fit. Call to 'writeStr'. Parameter: 'unsigned string & sData' is '"Sec-WebSocket-"' of type 'string'.
**Error**:'const' expressions does not fit. Call to 'writeStr'. Parameter: 'unsigned string & sData' is '"Accept: "' of type 'string'.
**Error**:Expression does not fit parameter. Call to 'nxtWriteRawHS'. Parameter: 'char * pData' is 'starttx' of type 'ubyte [3]'.
**Error**:'*' Indirection levels mismatch. Call to 'nxtWriteRawHS'. Parameter: 'char * pData' is 'byteData' of type 'byte'.
**Error**:Expression does not fit parameter. Call to 'nxtWriteRawHS'. Parameter: 'char * pData' is 'endtx' of type 'ubyte [2]'.
I am running RobotC 4.27. Any direction as to why this example program didn’t work would be helpful.
