I understand that the distance sensor offset can vary by temperature, and the measurement variation depends on the distance, reflectance, angle to reflector, and ambient lighting, but what I don’t understand is why the average of 100 readings would vary from the average of the next 100 readings by much?
Or why is the error in the average of two sets of the average of 50 readings lower than the error in the average of a set of 100?
(Statistics was one of my toughest classes…)
For N=2
3:41:59
Readings : 2
Reading Delay : 0.010 s
Average Reading: 774 mm
Minimum Reading: 774 mm
Maximum Reading: 775 mm
Std Dev Reading: 0 mm
Three SD readings vs ave reading: 0.2 %
Adjusted For Error Average Distance: 764 mm13:42:00
Readings : 2
Average Reading: 757 mm
Minimum Reading: 757 mm
Maximum Reading: 757 mm
Three SD readings vs ave reading: 0.0 %
Adjusted For Error Average Distance: 746 mmAverage Average: 766 mm
Minimum Average: 757 mm
Maximum Average: 774 mm
Std Dev Average: 9 mm
Three SD averages vs ave reading: 3.4 %
For N=10
13:44:02
Readings : 10
Average Reading: 764 mm
Minimum Reading: 754 mm
Maximum Reading: 780 mm
Std Dev Reading: 9 mm
Three SD readings vs ave reading: 3.7 %
Adjusted For Error Average Distance: 754 mm13:44:04
Readings : 10
Average Reading: 770 mm
Minimum Reading: 755 mm
Maximum Reading: 782 mm
Three SD readings vs ave reading: 3.4 %
Adjusted For Error Average Distance: 759 mmAverage Average: 767 mm
Minimum Average: 764 mm
Maximum Average: 770 mm
Std Dev Average: 3 mm
Three SD averages vs ave reading: 1.1 %
For N=50
13:49:40
Readings : 50
Average Reading: 769 mm
Maximum Reading: 784 mm
Std Dev Reading: 7 mm
Three SD readings vs ave reading: 2.8 %
Adjusted For Error Average Distance: 758 mm13:49:50
Readings : 50
Minimum Reading: 743 mm
Maximum Reading: 798 mm
Std Dev Reading: 10 mm
Three SD readings vs ave reading: 4.0 %
Adjusted For Error Average Distance: 759 mmAverage Average: 769 mm
Minimum Average: 769 mm
Std Dev Average: 0 mm
Three SD averages vs ave reading: 0.2 %
For N=100
Start: 13:44:15
Readings : 100
Maximum Reading: 788 mm
Three SD readings vs ave reading: 3.6 %
Adjusted For Error Average Distance: 758 mm13:44:34
Readings : 100
Minimum Reading: 749 mm
Maximum Reading: 794 mm
Adjusted For Error Average Distance: 760 mmAverage Average: 769 mm
Std Dev Average: 1 mm
Three SD averages vs ave reading: 0.3 %
