uname -a:
Linux raspberrypi 3.12.22+ #691 PREEMPT Wed Jun 18 18:29:58 BST 2014 armv6l GNU/Linux
lsusb:
Bus 001 Device 003: ID 0424:ec00 Standard Microsystems Corp.
Bus 001 Device 004: ID 0bda:8179 Realtek Semiconductor Corp.
The wifi dongle that DOES work and shows up on wlan0:
uname -a
lsusb
Bus 001 Device 005: ID 0bda:8176 Realtek Semiconductor Corp. RTL8188CUS 802.11n WLAN Adapter
find /lib/modules -type f -path “*wireless*” -name “*.ko”
Thanks for pasting that output John. It is the driver- and the new dongles have a green LED. Note that the one that works was 0bda:8176 with the 8192cu driver and the one that didn’t was the same as mine 0bda:8179 (and probably the same as Lucas).
The good news is there is a driver that works with the 8179 and apparently it’s bundled in the latest raspbian kernel already.
If you have the time, you should try compiling the 8188eu driver and see if it works for you and if you see a green LED
Lee’s directions were perfect and I got the non-working device to work by following them.
I have a truncated set of directions that will hopefully work. It would be awesome if anyone else with a bum wifi device from Dexter could test these. I’ve tried to make them as easy as possible.
1). Connect your pi to the internet. Since wifi isn’t working, this probably means connecting directly into your router and connecting via SSH.
2). In the command line type the following commands.
3). cd /lib/firmware/rtlwifi/
4). sudo wget http://www.dexterindustries.com/files/rtl8188eufw.bin
5). ‘sudo reboot’
This healed the problem for me. To make it easier and cleaner for anyone else wanting an immediate fix, I put the uncompressed bin file up on the DI page for download.
Hi John,
I copied rtl8188eufw.bin to /lib/firmware/rtlwifi/ as suggested in your recent post. The LED light on the wifi dongle is still not coming on. Do you have any other suggestions?
