Working AirQuality and MotionSensor in nodejs
I have successfully added the AirQuality and Motion Sensor with nodejs and just want to share the code with you.
AirQuality:
var AnalogSensor = require('./base/analogSensor')
var commands     = require('../commands')
function AirQualityAnalogSensor(pin) {
  AnalogSensor.apply(this, Array.prototype.slice.call(arguments))
AirQualityAnalogSensor.prototype = new AnalogSensor()
AirQualityAnalogSensor.prototype.read = function() {
  this.board.pinMode(this.board.INPUT)
  var res = AnalogSensor.prototype.read.call(this)
  return parseInt(res)
module.exports = AirQualityAnalogSensor
MotionSensor:
var DigitalSensor = require('./base/digitalSensor')
function MotionDigitalSensor(pin) {
  DigitalSensor.apply(this, Array.prototype.slice.call(arguments))
MotionDigitalSensor.prototype = new DigitalSensor()
MotionDigitalSensor.prototype.read = function()
  var write = this.board.writeBytes(commands.dRead.concat([this.pin, commands.unused, commands.unused]))
  if (write) {
    this.board.wait(200)
    var singleByte = this.board.readByte()
    var bytes = this.board.readBytes();
    return bytes[0];
module.exports = MotionDigitalSensor
Thanks a lot for sharing the code here. It would be great if you could send us a pull request here: https://github.com/DexterInd/GrovePi/tree/master/Software/NodeJS/libs/sensors so that we can merge it directly in the Github repository and others can use it too.
Agreed, thanks! Please share!
