I have just come back to using the GoPiGo after some time. I had it running fine, but now I am having difficulty. It starts up and I can VNC in via http://dex.local. When I attempt to run the demo or tests and troubleshooting, i get…
xlib: extension “RANDR” missing on display “:1.0”.
Must be connected to a terminal.
I am using the the image downloaded from Dexter Industries - Raspian for Robots. The follwing log file is created. Can you provide some assitance?
Check space left
/dev/root 7.1G 2.9G 4.0G 43% /
devtmpfs 428M 0 428M 0% /dev
tmpfs 87M 444K 86M 1% /run
tmpfs 5.0M 0 5.0M 0% /run/lock
tmpfs 173M 0 173M 0% /run/shm
/dev/mmcblk0p1 56M 20M 37M 36% /boot
Check for dependencies
python 2.7.3-4+deb7u1 install ok installed
python-pip 1.1-3 install ok installed
git 1:1.7.10.4-1+wheezy1+rpi2 install ok installed
libi2c-dev 3.1.1+svn-1 install ok installed
python-serial 2.5-2.1 install ok installed
python-rpi.gpio 0.6.1~wheezy-1 install ok installed
i2c-tools 3.1.1+svn-1 install ok installed
python-smbus 3.1.1+svn-1 install ok installed
arduino 1:1.0.1+dfsg-7 install ok installed
minicom 2.6.1-1 install ok installed
scratch 1.4.20131203-2 install ok installed
wiringPi Found
wiringPi Found
I2C-dev already there
i2c-bcm2708 already there
spi-dev already there
Hardware revision
gpio version: 2.26
Raspberry Pi Details:
Type: Model 2, Revision: 1.1, Memory: 1024MB, Maker: Sony
Check the /dev folder
i2c-1
spidev0.0
spidev0.1
ttyAMA0
USB device status
Bus 001 Device 003: ID 0424:ec00 Standard Microsystems Corp.
Bus 001 Device 004: ID 148f:5370 Ralink Technology, Corp. RT5370 Wireless Adapter
|__ Port 1: Dev 2, If 0, Class=hub, Driver=hub/5p, 480M
|__ Port 1: Dev 3, If 0, Class=vend., Driver=smsc95xx, 480M
|__ Port 3: Dev 4, If 0, Class=vend., Driver=rt2800usb, 480M
Checking for Atmega chip
Using Port : unknown
Using Programmer : gpio
AVR Part : ATMEGA328P
Chip Erase delay : 9000 us
PAGEL : PD7
BS2 : PC2
RESET disposition : dedicated
RETRY pulse : SCK
serial program mode : yes
parallel program mode : yes
Timeout : 200
StabDelay : 100
CmdexeDelay : 25
SyncLoops : 32
ByteDelay : 0
PollIndex : 3
PollValue : 0x53
Memory Detail :
Block Poll Page Polled
Programmer Type : GPIO
avrdude done. Thank you.
Checking I2C bus for devices
Checking I2C bus 0
Error: Could not open file /dev/i2c-0’ or/dev/i2c/0’: No such file or directory
Checking I2C bus 1
70: – -- – -- – -- – --
Checking for firmware version and CPU Speed and Voltage
v -1
CPU speed: -1
-1 V
CHECKING ENCODER READINGS
-1 -1
Both motors moving Forward with LED On
after 5 sec 0 0
Both motors stopped with LED Off
None after stop cmd 0 0
None after 2 more sec 0 0
Both motors moving back with LED On
after 5 sec 0 0
CHECKING ENCODER TARGETING
Initial encoder read vals: 0 0
Enc tgt Status: 1
Enc tgt Status: 1
Enc tgt Status: 1
Enc tgt Status: 1
Enc tgt Status: 1
Enc tgt Status: 1
Enc tgt Status: 1
Enc tgt Status: 1
Enc tgt Status: 1
Enc tgt Status: 1
Enc tgt Status: 1
FAIL
Final encoder read vals: 0 0
Enc tgt Status: 1
Enc tgt Status: 1
Enc tgt Status: 1
Enc tgt Status: 1
Enc tgt Status: 1
Enc tgt Status: 1
Enc tgt Status: 1
Enc tgt Status: 1
Enc tgt Status: 1
Enc tgt Status: 1
Enc tgt Status: 1
FAIL
Enc tgt Status: 1
Enc tgt Status: 1
Enc tgt Status: 1
Enc tgt Status: 1
Enc tgt Status: 1
Enc tgt Status: 1
Enc tgt Status: 1
Enc tgt Status: 1
Enc tgt Status: 1
Enc tgt Status: 1
Enc tgt Status: 1
FAIL
Enc tgt Status: 1
Enc tgt Status: 1
Enc tgt Status: 1
Enc tgt Status: 1
Enc tgt Status: 1
Enc tgt Status: 1
Enc tgt Status: 1
Enc tgt Status: 1
Enc tgt Status: 1
Enc tgt Status: 1
Enc tgt Status: 1
FAIL
Final encoder read vals: 0 2
Enc tgt Status: 1
Enc tgt Status: 1
Enc tgt Status: 1
Enc tgt Status: 1
Enc tgt Status: 1
Enc tgt Status: 1
Enc tgt Status: 1
Enc tgt Status: 1
Enc tgt Status: 1
Enc tgt Status: 1
Enc tgt Status: 1
FAIL
