Can the Arduberry and BrickPi be stacked together?
I’d like to add a few more analog sensors to my BrickPi robot.
Enric
Enric
Possibly, Yes. On BrickPi there is a little foam glued to the pins, so if you removed it you could physically do it, however I don’t know if having a hat ontop of a hat would mess stuff up. Another option is to get another Pi such as the A.
Then add arduberry on The second Pi and somehow make a robot that can support two pi’s, but that could be a bit overkill. I invited @Matt maybe he’d know more because he’s the dexter industries engineer expert guy.
Hi @ecervera,
Yes the BrickPi and the ArduBerry can be stacked together like this:
The stacking might be a little incomplete as the ArduBerry might not fit in properly on the BrickPi.
Note: BrickPi uses UART communication with the sensors and hence you should avoid using the Serial Monitor with the ArduBerry, for the BrickPi to work.
-Shoban
Thank you very much for the info.
I will order one and give it a try (with a GPIO connector extender)
Regards,
Enric
Hi @ecervera,
Thanks a lot for your interest on our products. Reach out to us if you need more help.
-Shoban
