I’m admittedly a novice in everything about this robot except that I’m an Avid Lego builder. I got the BrickPi3 about a month ago. I was able to make a simple program in Scratch to ensure all the motors/sensors and ports were working properly. I’ve been trying to make the BrowserBot project on GitHub work for me for about two weeks now. I know nothing about Python, so I see this as a good learning exercise. But I’m at a road block. I’ve made it to the last step of controlling the robot. I see there is communication (when I click the buttons on the browser html, I correctly get “running forward,” “steering left,” etc.) but I’m getting no response from the motors. They’re plugged into the correct ports and work properly when I run motor tests.
@graykevinb@lucaseubank111,
Here are a few pointers if you are getting the Browser streaming robot to work with the BrickPi3.
There is only 1 file which needs to be updated, this one. You can use the pointers from this and this to move the functionality from BrickPi to the BrickPi3.
