I have a problem with my Brickpi sensor.
Recently, when I use any sensors, BrickPisetup returns 0 (It’s OK), but BrickPiSetupSensors  returns -1. So It does not work.
when I try many times, BrickPiSetupSensors sometimes returns 0. And sensors work well. So I don’t think sensor’s breakdown.
What version of the BrickPi are you using?
I have a BrickPi+.
Can you share the code you’re running? With a BrickPi+, if you don’t have a pause in between the initiation and the sensor setup, you can cause and error. This could indeed be a dead sensor though.
Here is my code. I used github’s code as it is.
#include <stdio.h>
#include <math.h>
#include <time.h>
#include "tick.h"
#include "BrickPi.h"
#include <linux/i2c-dev.h>
#include <fcntl.h>
// Compile Using:
// sudo gcc -o program "EV3 - IR Sensor proximity test.c" -lrt -lm
// Run the compiled program using:
// sudo ./program
//#define DEBUG
int result,val;
//#undef DEBUG
#define IR_PORT         PORT_1                      // Infrared Sensor on Port_1
int main() {
  ClearTick();
  result = BrickPiSetup();
  printf("BrickPiSetup: %d\n", result);
  if(result)									// Check to see if everything is alive.
    return 0;									// If not, kill the program.
  printf("BrickPiSetup Done!\n");				// If so, proceed.
  BrickPi.Address[0] = 1;
  BrickPi.Address[1] = 2;
  BrickPi.SensorType[IR_PORT] = TYPE_SENSOR_EV3_INFRARED_M0;	// Setting SEnsor to mode 0.
  result = BrickPiSetupSensors();								// Call this to setup the sensors.
  printf("BrickPiSetupSensors: %d\n", result); 					// Print the result of sensor setup.
  if(!result){
    usleep(10000);
    while(1){
      result = BrickPiUpdateValues();			// Update values from the BrickPi.
      if(!result){
      	 val = BrickPi.Sensor[IR_PORT];			// Put values into a variable.
	     if(val <= 100)
           printf("Results: %d \n", val );		// Print the value returned.  This is the relative IR sensor, in this example.
	  //usleep(10000);
  return 0;
            Hmm . . . that leaves a question. Can you try modifying the code to have a few sleeps in it between calls? Something like this:
usleep(10000);
I think the calls may be made too rapidly to the BrickPi+, especially if you’re using a newer version of the Raspberry PI.
