After Raspbian Update, espeak issue
Ouch, why did I update?
aplay /usr/share/sounds/alsa/Front_Center.wav
is taking a long time before playing and cutting off the end of the audio,
and espeak is throwing:
pi@Carl:~/Carl/plib $ espeak "hello"
Expression 'alsa_snd_pcm_hw_params_set_period_size_near( pcm, hwParams, &alsaPeriodFrames, &dir )' failed in 'src/hostapi/alsa/pa_linux_alsa.c', line: 924
ALSA lib confmisc.c:1281:(snd_func_refer) Unable to find definition 'defaults.bluealsa.device'
ALSA lib conf.c:4528:(_snd_config_evaluate) function snd_func_refer returned error: No such file or directory
ALSA lib conf.c:4996:(snd_config_expand) Args evaluate error: No such file or directory
ALSA lib pcm.c:2495:(snd_pcm_open_noupdate) Unknown PCM bluealsa
connect(2) call to /tmp/jack-1000/default/jack_0 failed (err=No such file or directory)
attempt to connect to server failed
Expression 'parameters->channelCount <= maxChans' failed in 'src/hostapi/alsa/pa_linux_alsa.c', line: 1514
Expression 'ValidateParameters( outputParameters, hostApi, StreamDirection_Out )' failed in 'src/hostapi/alsa/pa_linux_alsa.c', line: 1846
Expression 'paInvalidSampleRate' failed in 'src/hostapi/alsa/pa_linux_alsa.c', line: 2048
Expression 'PaAlsaStreamComponent_InitialConfigure( &self->playback, outParams, self->primeBuffers, hwParamsPlayback, &realSr )' failed in 'src/hostapi/alsa/pa_linux_alsa.c', line: 2722
Expression 'PaAlsaStream_Configure( stream, inputParameters, outputParameters, sampleRate, framesPerBuffer, &inputLatency, &outputLatency, &hostBufferSizeMode )' failed in 'src/hostapi/alsa/pa_linux_alsa.c', line: 2843
wave_open_sound > Pa_OpenStream : err=-9997 (Invalid sample rate)
Luckily I did a rsync clone OS yesterday, and everything new was in Git, so I rolled back. I can’t expect you guys to debug my bot for me.
After running just the Raspbian updates, espeak is non-functional; it appears it has nothing to do with the DI software changes. (Other folks updating Stretch are reporting espeak issues as well.)
Simply running:
sudo apt-get update
sudo apt-get upgrade
$ uname -a
Linux Carl 4.19.66-v7+ #1253 SMP Thu Aug 15 11:49:46 BST 2019 armv7l GNU/Linux
leaves espeak no longer functioning.
Actually, additionally…
Now aplay is cutting off the last part of a wav file :
says “Front Cent” without the “er” which it previously played flawlessly.
espeak stopped working completely until I added the following to my /home/pi/.bashrc:
PA_ALSA_PLUGHW=1
export PA_ALSA_PLUGHW
(and rescanned with source .bashrc )
Now espeak is working but the speech has a lot of distortion.
(regardless of my alsamixer pcm output level btw)
Here’s what we’ve done for espeak:
# fix espeak
# 1. set audio to the audio jack
amixer cset numid=3 1
# 2. set volume to 100%
sudo amixer set PCM -- 100%
# 3. remove current espeak
sudo apt-get remove -y espeak
# 4. reinstall espeak and helpers
sudo apt install -y espeak python3-espeak speech-dispatcher-espeak
I have not noticed any distortion but I also haven’t played with it extensively.
Thanks for the reply.
Interesting result - There is still a little distortion, but now there is a 10-15 second silence before espeak outputs the speech, and did not fix the aplay cutting off the end of wav file playback.
I got rid of the delay by removing pulseaudio
sudo apt-get remove pulseaudio
Ignoring the errors, it does speak:
pi@Carl:~/Carl $ espeak "hello there. Am I speaking with any distortion now with the speech-dispatcher installed?"
and for reference, before the update espeak generated a shorter list of errors:
pi@Carl:~/Carl $ espeak "hi"
Continued investigations:
  1. install espeak-ng
    sudo apt-get install espeak-ng
  2. Either revert the kernal to 4.14.66
    sudo rpi-update a08ece3d48c3c40bf1b501772af9933249c11c5b
    sudo reboot
    or
    take the latest “alpha” kernal:
    sudo rpi-update
    sudo reboot
Both of these will fix the cutoff issue and espeak-ng; Only reverting the kernal will fix espeak (non -ng version).
That is good to know, about the kernel. Thanks for the investigation!
