Hi there!
I’m using python to program my BrickPi.
I’m rotating the motor by 90 degrees by using set_motor_position()
. After it’s finished I want to let the motor rotate freely, so I call BP.set_motor_power(BP.PORT_A, BP.MOTOR_FLOAT)
. The problem is that I have to wait with time.sleep(0.5)
until the motor finishes the movement and in the meantime I can’t log or use it’s sensor value which would be really important for my use-case.
Is there a way to make the motor rotate asynchronously so in the meantime I can do other things in the program?
Thanks for the help!
