mw46d
September 27, 2014, 4:23pm
I don’t know since when, but it looks like the currently installed wiringPi library can’t handle the required Baud rate:-(
pi@dexter ~/src/wiringPi/wiringPi $ ls -l /usr/local/lib/libwiringPi*
lrwxrwxrwx 1 root staff 21 Jul 29 04:35 /usr/local/lib/libwiringPiDev.so -> libwiringPiDev.so.2.0
-rwxr-xr-x 1 root staff 23229 Jul 29 04:35 /usr/local/lib/libwiringPiDev.so.2.0
lrwxrwxrwx 1 root staff 18 Jul 29 04:35 /usr/local/lib/libwiringPi.so -> libwiringPi.so.2.0
-rwxr-xr-x 1 root staff 48107 Jul 29 04:35 /usr/local/lib/libwiringPi.so.2.0
When I try to do a BrickPiSetup(), everything seems fine, but the call to serialOpen() actually returns -2!! The BrickPiSetup() code only checks for -1, so it claims success:-(
The current code of serialOpen() (wiringPi/wiringSerial.c ) shows clearly that it will return a -2 when it does not understand the Baud rate:-(
So, the question is, did you have a different wiringPi library at some point?
I’ll probably hack the lib source and see how far I get.
– Marco
mw46d
September 27, 2014, 4:54pm
OK, I patched the wiringPi library;-)
diff --git a/wiringPi/wiringSerial.c b/wiringPi/wiringSerial.c
index ca976a9..567e692 100644
--- a/wiringPi/wiringSerial.c
+++ b/wiringPi/wiringSerial.c
@@ -67,6 +67,42 @@ int serialOpen (const char *device, const int baud)
case 57600: myBaud = B57600 ; break ;
case 115200: myBaud = B115200 ; break ;
case 230400: myBaud = B230400 ; break ;
+#ifdef B460800
+ case 460800: myBaud = B460800 ; break ;
+#endif
+#ifdef B500000
+ case 500000: myBaud = B500000 ; break ;
+#endif
+#ifdef B576000
+ case 576000: myBaud = B576000 ; break ;
+#endif
+#ifdef B921600
+ case 921600: myBaud = B921600 ; break ;
+#endif
+#ifdef B1000000
+ case 1000000: myBaud = B1000000 ; break ;
+#endif
+#ifdef B1152000
+ case 1152000: myBaud = B1152000 ; break ;
+#endif
+#ifdef B1500000
+ case 1500000: myBaud = B1500000 ; break ;
+#endif
+#ifdef B2000000
+ case 2000000: myBaud = B2000000 ; break ;
+#endif
+#ifdef B2500000
+ case 2500000: myBaud = B2500000 ; break ;
+#endif
+#ifdef B3000000
+ case 3000000: myBaud = B3000000 ; break ;
+#endif
+#ifdef B3500000
+ case 3500000: myBaud = B3500000 ; break ;
+#endif
+#ifdef B4000000
+ case 4000000: myBaud = B4000000 ; break ;
+#endif
default:
return -2 ;
I hope that helps somewhat;-)
Have fun,
– Marco
