I have a BrickPiAdvanced module bought from reseller in Luxembourg ( electronic-shop.lu ) and when I run the LEGO-Motor-TEST i keep getting Error: -1 every few seconds. I’ve also tried the sensor test script but that one doesn’t work either. Here is my configuration:
- Raspberry Pi B
 - External power supply through universal DC converter (500mA)
 - Tried with both Dexter Image V6.7, build 2016.01.04 and with Raspbian and following step-by-step instruction for modifying the image. Same thing in both cases
 - IR ports have been disabled
 - I got the blue LED working but thins doesn’t mean much, right? It’s just GPIO from the Pi
 - Error -2 means that the board is not recognized at all, right?
Here is the output of the troubleshoting.sh script:
troubleshooting_script_v1
Check for dependencies
python 2.7.3-4+deb7u1 install ok installed
python-pip 1.1-3 install ok installed
git 1:1.7.10.4-1+wheezy1+rpi2 install ok installed
libi2c-dev 3.1.1+svn-1 install ok installed
python-serial 2.5-2.1 install ok installed
python-rpi.gpio 0.5.11-1 install ok installed
i2c-tools 3.1.1+svn-1 install ok installed
python-smbus 3.1.1+svn-1 install ok installed
arduino 1:1.0.1+dfsg-7 install ok installed
minicom 2.6.1-1 install ok installed
scratch 1.4.20131203-2 install ok installed
wiringPi Found
wiringPi Found
I2C-dev already there
i2c-bcm2708 already there
spi-dev already there
Setup for Serial for BrickPi
Clock speed Configured
Serial Port not Enabled(ERR)
Serial Port Login Already Disabled
Hardware revision
gpio version: 2.31
Raspberry Pi Details:
Type: Model B, Revision: 03, Memory: 512MB, Maker: Egoman
Device tree is enabled.
This Raspberry Pi supports user-level GPIO access.
Read pins
±----±----±--------±-----±–±Model B2-±–±-----±--------±----±----+
| BCM | wPi |   Name  | Mode | V | Physical | V | Mode | Name    | wPi | BCM |
|     |     |    3.3v |      |   |  1 || 2  |   |      | 5v      |     |     |
|   2 |   8 |   SDA.1 | ALT0 | 1 |  3 || 4  |   |      | 5V      |     |     |
|   3 |   9 |   SCL.1 | ALT0 | 1 |  5 || 6  |   |      | 0v      |     |     |
|   4 |   7 | GPIO. 7 |   IN | 1 |  7 || 8  | 1 | ALT0 | TxD     | 15  | 14  |
|     |     |      0v |      |   |  9 || 10 | 1 | ALT0 | RxD     | 16  | 15  |
|  17 |   0 | GPIO. 0 |   IN | 0 | 11 || 12 | 0 | IN   | GPIO. 1 | 1   | 18  |
|  27 |   2 | GPIO. 2 |   IN | 0 | 13 || 14 |   |      | 0v      |     |     |
|  22 |   3 | GPIO. 3 |   IN | 0 | 15 || 16 | 0 | IN   | GPIO. 4 | 4   | 23  |
|     |     |    3.3v |      |   | 17 || 18 | 0 | IN   | GPIO. 5 | 5   | 24  |
|  10 |  12 |    MOSI | ALT0 | 0 | 19 || 20 |   |      | 0v      |     |     |
|   9 |  13 |    MISO | ALT0 | 0 | 21 || 22 | 0 | IN   | GPIO. 6 | 6   | 25  |
|  11 |  14 |    SCLK | ALT0 | 0 | 23 || 24 | 1 | OUT  | CE0     | 10  | 8   |
|     |     |      0v |      |   | 25 || 26 | 1 | OUT  | CE1     | 11  | 7   |
|  28 |  17 | GPIO.17 |   IN | 0 | 51 || 52 | 0 | IN   | GPIO.18 | 18  | 29  |
|  30 |  19 | GPIO.19 |   IN | 0 | 53 || 54 | 0 | IN   | GPIO.20 | 20  | 31  |
Check I2C
00:          – -- – -- – -- – -- – -- – -- –
70: – -- – -- – -- – --
Check the /dev folder
i2c-1
spidev0.0
spidev0.1
ttyAMA0
=USER STATS=
BrickPi Found
Arduberry Found
grovePi Found
GoPiGo Not Found
BrickPiStatus
-2
BrickPi Not Found (ERR)
Does it look to you that the boaqrd is faulty or do you see anything else might be a problem from the output? If it helps you, attached is photo of my board.
Thank you.
