how do the voltage functions work? (int vs. float)
// Get the voltages of the four power rails
int get_voltage_3v3 (float &voltage);
float get_voltage_3v3 ();
int get_voltage_5v (float &voltage);
float get_voltage_5v ();
int get_voltage_9v (float &voltage);
float get_voltage_9v ();
int get_voltage_battery(float &voltage);
float get_voltage_battery();
If you use e.g. float get_voltage_5v(); it will return the voltage of the 5v rail if it’s successful, otherwise it will return the error (which will be < 0).
If you use e.g. int get_voltage_5v (float &voltage); it will return the error code, and through the pass-by-reference it will return the voltage of the 5v rail (unless the error code is not ERROR_NONE, in which case the voltage value will probably be 0).
Either way the voltage is returned as a floating point voltage e.g. 5.025 if it is read successfully.
