I have no problem controlling the robot using the DexterOS either thru Bloxter, Advanced Bloxter, or Python; however, when I use Raspbian for Robots OS, I cannot control the robot from the command window
(https://www.dexterindustries.com/GoPiGo/projects/python-examples-for-the-raspberry-pi/basic-robot-control-with-the-raspberry-pi-gopigo/)
or by launching Scratch from the desktop.
It appears there is no communication between Raspbian for Robots and the GoPiGo3
Hi @terryandunha,
When running Raspbian For Robots on your Raspberry Pi, please make sure:
Then run the following commands inside a terminal session in the following order (by the way, follow any given instructions, even if it asks you to reboot the machine):
sudo curl -kL dexterindustries.com/update_gopigo3 | bash
python /home/pi/Dexter/GoPiGo3/Software/Python/Examples/Read_Info.py
After you do this, please come back with a screenshot/results of what you got - this should solve your issue though.
