Colorsensor and connection problems
hello john,
it is a pity that you do not answer my connection problems. i given up the brickPi because the sensors don’t works.
but now my colorsensor is broke. it do not will operate an the LEGO Brick anymore. Is it possible that the reason for this is the brickPI?
R. Kees Kemps
Hi Keeskemps, I think we tried really hard to answer your connection problems; where did we leave off?
I don’t think this is possible.
Best,
John
HI John,
I think we did both our best, but the result is pathetic.
I made a new Sd cart. But it give non change.
there is connection with te motor, but no connection with the toutchsensor
and the colorsensor.
I tested it with the scrtach testprograms.
I aked you several times for help, but on the last aks you give me no
response.
So, I give it up; a pity for the money.
And now the color sensor is broken. That is a new fact. I had no problems
with the colorsensor.
I asked Lego for help and Lego give me instructions for rebooting, without
result.
The service of Lego is exccelllent. They send me a new colorsensor for free.
But … how is this all posseble?
R . Kees kemps The Netherlands
Tanks for your help, but it do not help.
the colorsensor gives the same value with all colors.
the 2 possibility: the flexted light works also not.
The 3th possibility: the lght from outsite gives good results.
The sensor gives differend light in the tree possibilitys.
det now.?
I have only one brick, but the brick is oke.
R. Kees
Sorry to hear about all the troubles. We really are trying, but it seems you are having a lot of trouble.
I don’t quite understand: is the color sensor turning on with the BrickPi? Or just the NXT brick?
Hoi John
I have a LEGO Ev3 brick.
THE colorsensor is connecked with THE Ev3 but gives not a good result.
R kees
So if your color sensor doesn’t work with the EV3 brick, you should contact lego about this. It sounds like you may have defective hardware, or may be be having trouble running their software.
John,
Do you mot remmenservice that i tell you that LEGO give me à new sensor?
That is nog THE question!!!
THE problem is that THE sensor went broke when I used it with Your Pi.
And my big problem is that I do nog have à connection with THE sensors
color and touch.
See earlier mails please.
R kees
Hello John
Do you mot rember that I tell you that LEGO give me an new sensor?
THE question and THE problem is that THE sensor went broke when I used it
with Your Pi.
color and touch.
See my earlier mails please.
R kees
