Hi John, and thanks for the answers.
1 -
THis line, BrickPi.MotorSpeed[PORT_A]=200; means you’re setting the motor on Port A to 200 power (out of a max of 255).
Ok - I got that. But for how long?
To me, it seems like it moves when I
call BrickPiUpdateValues();
BUT, just for a short while.
The code above calls
in a loop.
That, I guess, I s really my question.
How do I get it to run continuously?
And more interestingly, what is the trick to makes it rotate a fixed number of degrees?
2 - sorry if I was unclear.
I have 4 touchsensors and 2 light-sensors.
And I cannot get resonanble readings from any of them.
I connect the touchsensor to S1,
and run
it loops and prints the sensor input on screen, but its about 90 % 1’s and 10 % 0’s. even if I don’t touch the button. And it makes no difference if I press the button. still same distribution 90/10
For the light sensor I’ve tested
which also gives me random results.
I then tried
https://github.com/DexterInd/BrickPi_C/blob/master/Sensor_Examples/General%20-%20AnalogSensor%20test.c
But that did not light the leds up.
That I guess is bad. (seem to remember that from my rcx at the turn of the millennium. Yes, I’m that old)
The sensors I have are number two and three in
the second picture
3 - Error message from unpowered brickpi,
does it show even if DEBUG is not defined ?
looking at BrickPiRx in BrickPi.h I only see
num bytes received if debug is enabled.
That is 8 or 11 alternatively if I remember correctly
(at work now)
(im using BrickPi.H at
the BrickPi is powered from external 9v battery, but it is attached to the Raspberry Pi. Does not the mcus of the brickpi pick power from the raspberry?
I see a wonderful product here, but I miss some notes about how to use the api - more than the code samples.
I’m building a Tic-Tac-Toe bot.
I once did that with the rcx in Lejos, so that is fairly familiar grounds. Not using Lejos this time though.
/Björn
