I’m trying to do programming, and firstly I try to run this samples code,(arm_test.py) and then My motor wouldn’t rotate, and I got some error message.
That is;
When I push run,
run arm_test.py
File”/user/lib/python3/dist-
packages/serial/serialposix.py”,line 265,
in open
Self .fd=os.open( self.portstr, os0_RDWR |
os.0_NOCTTY | os.0_NONBLOCK)
PermissionError: [errno 13] permission denied:
‘/dev/ttyAMA0’
And I can’t figure out how to fix the problem….
I’ll paste sample code which I use to make sure below:
from BrickPi import * #import BrickPi.py file to use BrickPi operations
roller =PORT_A
arm= PORT_B
BrickPiSetup() #setup the serial port for communication
BrickPi.MotorEnable[roller] = 1 #Enable the Motor A
BrickPi.MotorEnable[arm] = 1 #Enable the Motor B
speed_roller=100
speed_arm=100
t1=.3
t2=.9
#Move the roller to bring up the page
BrickPi.MotorSpeed[roller] = -speed_roller
ot = time.time()
while(time.time() - ot < t1):
BrickPiUpdateValues()
init_pos=BrickPi.Encoder[arm]
time.sleep(.1) # sleep for 100 ms
time.sleep(2)
BrickPi.MotorSpeed[roller] = -50
BrickPi.MotorSpeed[arm] = speed_arm
#Rotate the arm to flip the page and stop at the initial position
if(BrickPi.Encoder[arm]-init_pos>710):
BrickPi.MotorSpeed[arm] = -85
time.sleep(.1)
BrickPi.MotorSpeed[arm] = 0
time.sleep(.01)
break
time.sleep(.01) # sleep for 100 ms
#Move the roller to bring pages down
time.sleep(2)
BrickPi.MotorSpeed[roller] = 60
ot = time.time()
while(time.time() - ot < 3): #running while loop for 3 seconds
BrickPiUpdateValues() # Ask BrickPi to update values for sensors/motors
time.sleep(4)
