The end of the install process has several errors. Are these normal, or did I do something wrong?
Removing blacklist from /etc/modprobe.d/raspi-blacklist.conf . . .
grep: /etc/modprobe.d/raspi-blacklist.conf: No such file or directory
sed: can't read /etc/modprobe.d/raspi-blacklist.conf: No such file or directory
I2C removed from blacklist
sed: can't read /etc/modprobe.d/raspi- lacklist.conf: No such file or directory
SPI removed from blacklist
Adding I2C-dev and SPI-dev in /etc/modules . . .
I2C-dev added
i2c-bcm2708 added
spi-dev added
Setting up i2c speed...
gpio: Warning: File not present: /dev/i2c-0
gpio: Warning: File not present: /dev/i2c-1
Setting up UART clock speed...
Enabling serial pins...
Disabling Serial Port Login...
Already Disabled
File "setup.py", line 14, in <module>
install_requires=open('requirements.txt').readlines(),
IOError: [Errno 2] No such file or directory: 'requirements.txt'
Restarting
Broadcast message from root@raspberrypi (pts/0) (Mon Feb 8 00:01:05 2016):
The system is going down for reboot NOW!
I’ll give that a try, but since the BrickPi modifications to the default OS are fairly minor, I was hoping to use the installation script on top of a default OS installation.
Are you certain that your pre-setup Raspbian for Robots image will continue to work even after I run apt-get upgrade?
I just updated that installer.sh so it doesn’t call on the setup.py. Since there’s nothing in the directory anyway, it should be something done dependent on the language you’re running. I’ll try to make a more streamlined installation for this soon. Thanks for bringing it up!
The errors at the end are gone now, but I still see the two “sed: can’t read /etc/modprobe.d/raspi-blacklist.conf: No such file or directory” errors, as well as these two:
I’m assuming these are harmless warnings, but I haven’t tried using the software yet.
