Errors
got my BrickPi few days ago. Having problems maintaining communication with motors. If I run an Example: Run a motor back and forth script from http://www.dexterindustries.com/program-it/python/brickpi-python-idle/
after few cycles i get this error:
('Unexpected error: ', <class 'serial.serialutil.SerialException'>)
  File "robo.py", line 13, in <module>
    run_motors()
  File "robo.py", line 11, in run_motors
    BrickPiUpdateValues()
  File "build/bdist.linux-armv7l/egg/BrickPi.py", line 553, in BrickPiUpdateValues
  File "build/bdist.linux-armv7l/egg/BrickPi.py", line 701, in BrickPiRx
  File "/usr/lib/python2.7/dist-packages/serial/serialposix.py", line 435, in inWaiting
    s = fcntl.ioctl(self.fd, TIOCINQ, TIOCM_zero_str)
sometimes I get:
    run_motors()
  File "robo.py", line 8, in run_motors
  File "build/bdist.linux-armv7l/egg/BrickPi.py", line 551, in BrickPiUpdateValues
  File "build/bdist.linux-armv7l/egg/BrickPi.py", line 680, in BrickPiTx
  File "/usr/lib/python2.7/dist-packages/serial/serialposix.py", line 489, in write
    raise SerialException('write failed: %s' % (v,))
serial.serialutil.SerialException: write failed: [Errno 5] Input/output error
Have tried running on batteries, 12W iPad charger, 10W random USB charger… Always the same.
So you’re using idle with Python?
Are you using Raspbian for Robots or another operating system?
Also, if you run this python script from the command line:
https://github.com/DexterInd/BrickPi_Python/blob/master/Sensor_Examples/LEGO-Motor_Test.py
Does the program run continuously?
Thanks for the link Keymaster. I was able to resolve the issue:
I am running a Raspbian Jessie. Setup script run fine, but was not able to disable getty.
disabled getty with
sudo systemctl disable serial-getty@ttyAMA0.service
edited /boot/cmdline.txt
All examples now work as expected.
Great to hear. Thanks for letting us know.
