Ahaaa,
This is what you meant:
After you close this connection, turn off the automatic update and do not delete the current desktop image.
Jim my friend, I owe you a beer. If you ever feel like visitin Slovenia give me a call ![]()
I will document how my project goes and will probably create a few videos to ease anyones pain.
Thank you for all the help. I really appreciate it. I hope you are enjoying the time with your granddaughters in Moscow.
Don’t worry about the beer, I owe folks here so many beers I’d have to be a brewery to keep up.
However, Slovenia sounds like a great place to visit. I saw an article on YouTube that claimed that Slovenia has the best looking ladies on the planet!
Hmmm. . . Then again, maybe that’s not such a great idea - my wife is a jealous god and will probably kill me! (Just kidding!
So, remind me what this project is all about?
Maybe you can start a thread here to document your project and its progress? We all do things like that - it’s great for getting ideas and help when you get stuck.
Here’s a couple of things I do to make my life easier:
/usr/share/rpd-wallpaper/GPG-desktop-bg.pngViz.:
I also do some special file-system configurations to protect from bit-rot.
sudo tune2fs -c 5 -C 6 -i 5 -e remount-ro -o discard /dev/mmcblk0p2
Tune2fs allows you to program special features directly into the filesystem’s superblock.
I also edit the /etc/fstab file:
sudo mousepad /etc/fstab
and add “,discard” (comma-‘discard’) at the end of the line for the root filesystem
Viz.:
PARTUUID=ca78f9f0-02 / ext4 defaults,noatime,discard 0 1
where I add a comma and “discard” to the end of the option string. This also helps enable TRIM.
There are a few other things you need to do at the system level to guarantee TRIM is enabled, but I’d have to look them up.
Yes, because all of the balkan girls are gathering here ![]()
As for my project, the project name is:
Teaching shortest path algorithms using a physical robot.
Basically, I will give users user interface which will be a simple web page. They can draw a graph like graph in graph theory in it, with vertices, then connect those vertices with some edges and give them edge weights. Then they chose one out of three algorithms for finding a shortest path, and I will visually show them how the algorithm works, with some help from Timmy of course.
I will conduct a quick user study, give participants some graphs to find shortest path algorithms after learning the algorithms. Then we will see how well they implement them.
So, basically that is that.
If I continue master’s here I would probably ask to be in charge of the GoPiGo’s so I can work on some more interesting projects. It would be fun I think.
A-star, traveling salesman, ?
I have Dijkstra’s ready, I was thinking on A-Star, but I am still not sure which other two I will use.
That sounds interesting!
You are going to keep us up to date with your progress, right?
P.S.
Get TWO robots and do things with both of them!
Very neat to hear! Forty years ago I was tasked to design an autonomous aerial vehicle flight path planner that maximized the probability of “discovering” carefully hidden objects (objects with a set of travel and operational constraints), while minimizing the likelihood of my vehicle being discovered prematurely, all within the vehicle flight constraints.
The solution was to combine an A-star planner with a rule-based inference engine all written in Lisp. (There was a group debate over A-star versus Traveling Salesman since our computational resources were so restricted.) Once the rules were set, I recoded the rules in CLIPS a C language Inference engine developed by NASA.
Our initial “test robot” was a video camera that “flew” (moved in {Y, Z, Psi, Phi} ) over top of a giant motion table that moved back and forth in X dimension under the camera providing visual and other simulated sensor inputs. On the table were scaled roads, vegetation, poles/towers/wires, buildings and the hidden objects.
Our whole team would get motion sickness during simulation testing (and the LISP computers would overheat). Crazy fun!
I will probably make a new post regarding the progress, and how everything is going. I wanted to start blogging for a while now, I just need to find the time to actually start it ![]()
As for getting two robots, I might try something in the future.
Hearing 40 years ago is actually already impressive enough for me.
You seemed to had a lot of fun working on that project. Probably making the scaled objects was a lot of fun also as well as running the simulation.
I am using a projector to show the graphs, but in the future I might make them more fun:
Making the vertices be towns, and the edges roads, etc. It would be more immersive I think.
Thanks @jimrh for all the explanations you gave @PavelCodes .
GoPiGo OS is both a system you can access through the browser and a system you can access through VNC to get to the Pi Desktop.
GoPiGo OS is both a system that runs its own Access Point, and a system that can be connected to the internet.
Hey everyone,
I have successfuly finished the project and my thesis. I would like to thank everyone for the help. I really appreciate it and I could not have done it without you.
Thank you again and I wish you all the best.
Best,
Pavel.
Congrats!!! Always a relief to finish a thesis!
You are all very welcome.
I still say that GoPiGo O/S is way underrated as a robotics platform. ![]()
It was an honor and a privilege to have been able to help.
If it’s not too much trouble, (and if you’re not slammed with finals!), can you give us a rundown on what happened, what you did, and how it worked out, (and maybe some code), in a separate thread?
P.S.
Since you already have the robot now, don’t be a stranger! I, for one, would love to see what else you can do with this.
