How to attach GrovePI sensors to a case
Hello all,
For a prototype project, we have connected a Raspberry Pi with the GrovePi shield and several sensors (7 or so). Now, we have all the wires and sensors just ‘hanging’ attached to the Pi. Is there somewhere a case, or an easy way to fix these sensors better and make things a little bit more solid on the hardware level?
Hello @sam.vanhoutte
You have two choices:
  1. acrylic sensor mounts:
    https://www.dexterindustries.com/shop/acrylic-sensor-mounts-set-of-4/
  2. plastic sensor mounts:
    https://www.dexterindustries.com/shop/sensor-mount/
Both work with almost all Grove sensors but it depends on your case and what your case has to connect the sensor mounts.
Hope it helps,
