Finally got my little robot working properly today. I added timeouts to the wait_for_motors_to_stop() function, and also did some commenting and refactoring (apologies for the code quality I’m still learning Python)
Wrapper round brickpi3 class to provide higher level functions
class Movement():
# Constants for current robot
WHEEL_DIAMETER = 8.2 # CM
GEAR_RATIO = 12 / 20 # 12t:20t
WHEEL_TRACK_WIDTH = 15.00 # CM (nice round number, what are the chances!)
LEFT_MOTOR = None
RIGHT_MOTOR = None
BP = None
def __init__(self, BP, left_motor, right_motor):
self.LEFT_MOTOR = left_motor
self.RIGHT_MOTOR = right_motor
self.BP = BP
def drive_in_circle(self, isRightHand, radius, speed):
Sets motor speeds to drive in an un-ending circle with specified radius
Note: radius is measured to the inner driving wheel, not the further out one.
Note: ratio(WheelSpeed1:WheelSpeed2) = ratio(CircleRadius:(CircleRadius+TrackWidth))
if radius == 0:
outer_wheel_speed = speed
inner_wheel_speed = 0
elif radius > 0:
fraction = radius / (radius + self.WHEEL_TRACK_WIDTH)
inner_wheel_speed = outer_wheel_speed * fraction
if isRightHand:
self.BP.set_motor_dps(self.LEFT_MOTOR, outer_wheel_speed)
self.BP.set_motor_dps(self.RIGHT_MOTOR, inner_wheel_speed)
else:
self.BP.set_motor_dps(self.LEFT_MOTOR, inner_wheel_speed)
self.BP.set_motor_dps(self.RIGHT_MOTOR, outer_wheel_speed)
def _distance_to_motor_degrees(self, distance):
wheel_circumference = math.pi * self.WHEEL_DIAMETER
num_wheel_revolutions = distance / wheel_circumference
num_motor_revolutions = num_wheel_revolutions / self.GEAR_RATIO
motor_degrees = 360 * num_motor_revolutions
# print(" motor_degrees: {}".format(motor_degrees))
return motor_degrees
def rotate_left(self, angle):
Rotates the robot on the spot by the angle in degrees by rotating one
motor forward and the other backward by an equal amount.
fraction_of_circle = angle / 360
required_distance = fraction_of_circle * (math.pi * self.WHEEL_TRACK_WIDTH)
motor_degrees = self._distance_to_motor_degrees(required_distance)
self.BP.set_motor_position_relative(self.LEFT_MOTOR, motor_degrees)
self.BP.set_motor_position_relative(self.RIGHT_MOTOR, -motor_degrees)
def rotate_right(self, angle):
self.BP.set_motor_position_relative(self.LEFT_MOTOR, -motor_degrees)
self.BP.set_motor_position_relative(self.RIGHT_MOTOR, motor_degrees)
def turn_left(self, angle):
Turns the robot by stopping one wheel and driving the wheel on the opposite side
by a certain amount.
required_distance = fraction_of_circle * (math.pi * 2 * self.WHEEL_TRACK_WIDTH)
self.BP.set_motor_position_relative(self.LEFT_MOTOR, 0)
def turn_right(self, angle):
self.BP.set_motor_position_relative(self.RIGHT_MOTOR, 0)
def move_forward(self, distance):
motor_degrees = self._distance_to_motor_degrees(distance)
def move_backward(self, distance):
def stop_both(self):
def wait_for_motors_to_stop(self, timeout_seconds = 10):
This function pauses (time.sleep) until the motors have stopped moving. This
is useful for blocking execution until the motors have rotated to a specified
angle.
Note: Includes timeouts, so only designed for use with turn_left\right,
rotate_left\right functions, move_forward or move_backward functions.
timeout_time_to_start = time.time() + 0.5
while not self.is_moving():
time.sleep(0.05)
if time.time() > timeout_time_to_start:
print("WARN: Timeout waiting for motors to start")
break
timeout_time_to_stop = time.time() + timeout_seconds
while self.is_moving():
time.sleep(0.1)
if time.time() > timeout_time_to_stop:
print("WARN: Timeout waiting for motors to stop")
break
def is_moving(self):
return (self.BP.get_motor_status(self.LEFT_MOTOR)[3] != 0) or (self.BP.get_motor_status(self.RIGHT_MOTOR)[3] != 0)
and my main file calls this class as follows:
import brickpi3
BP = brickpi3.BrickPi3()
LEFT_MOTOR = BP.PORT_B
RIGHT_MOTOR = BP.PORT_C
M = robot_movement.Movement(BP, LEFT_MOTOR, RIGHT_MOTOR)
<snip>
left_distance, center_distance, right_distance = read_ultrasonics()
# Default action
action = 'forward'
if left_distance < 20 or right_distance < 20:
if left_distance < right_distance:
action='right'
else:
action='left'
if center_distance < 20:
action='reverse'
if action == 'forward':
BP.set_motor_dps(LEFT_MOTOR, 200)
BP.set_motor_dps(RIGHT_MOTOR, 200)
elif action == 'reverse':
M.move_backward(30)
M.wait_for_motors_to_stop()
if random.choice([True, False]):
M.rotate_left(90)
else:
M.rotate_right(90)
elif action == 'right':
M.rotate_right(90)
elif action == 'left':
M.rotate_left(90)
Works great, the robot successfully avoids obstacles
Now to put some spinning blades on it, and get it to cut my lawn!
