i2c is not connecting
led_blink does not blink, but software runs
- led on
- led off
- led on
- led off
Brand new to Pi & Grove, so bear with me.
Using a 3b+.
Installed Grove Pi+ on top of Raspbian. (Not Raspbian for Robots).
My understanding is that this should work.
I have run a bunch of scripts & installers, but am not sure of what I am doing exactly.
Here is my system info
PRETTY_NAME=“Raspbian GNU/Linux 9 (stretch)”
NAME=“Raspbian GNU/Linux”
VERSION_ID=“9”
VERSION=“9 (stretch)”
ID=raspbian
ID_LIKE=debian
firmware has been updated
Managed to get the “focus” message or whatever that was.
** i believe it is mounted properly.**
Here is all_tests.sh log
Check space left
/dev/root 15G 4.5G 9.4G 33% /
devtmpfs 460M 0 460M 0% /dev
tmpfs 464M 0 464M 0% /dev/shm
tmpfs 464M 13M 452M 3% /run
tmpfs 464M 0 464M 0% /sys/fs/cgroup
/dev/mmcblk0p1 42M 21M 21M 51% /boot
tmpfs 93M 4.0K 93M 1% /run/user/1000
Check for dependencies
python 2.7.13-2 install ok installed
python-pip 9.0.1-2+rpt2 install ok installed
git 1:2.11.0-3+deb9u7 install ok installed
libi2c-dev 3.1.2-3 install ok installed
python-serial 3.2.1-1 install ok installed
python-rpi.gpio 0.6.5~stretch-1 install ok installed
i2c-tools 3.1.2-3 install ok installed
python-smbus 3.1.2-3 install ok installed
I2C still in blacklist
SPI still in blacklist
I2C-dev already there
i2c-bcm2708 already there
spi-dev already there
Hardware revision
File “”, line 1, in
ImportError: No module named ‘auto_detect_rpi’
Check the /dev folder
i2c-1
ttyAMA0
USB device status
Bus 001 Device 004: ID 0424:7800 Standard Microsystems Corp.
Bus 001 Device 003: ID 0424:2514 Standard Microsystems Corp. USB 2.0 Hub
Bus 001 Device 002: ID 0424:2514 Standard Microsystems Corp. USB 2.0 Hub
|__ Port 1: Dev 2, If 0, Class=Hub, Driver=hub/4p, 480M
|__ Port 1: Dev 3, If 0, Class=Hub, Driver=hub/3p, 480M
|__ Port 1: Dev 4, If 0, Class=Vendor Specific Class, Driver=lan78xx, 480M
Raspbian for Robots Version
Hostname
raspberrypi
Checking I2C bus for devices
Checking I2C bus 0
NOTE: it is normal for this one to fail
Error: Could not open file /dev/i2c-0' or
/dev/i2c/0’: No such file or directory
Checking I2C bus 1
00: – – – – – – – – – – – – –
10: – – – – – – – – – – – – – – – –
20: – – – – – – – – – – – – – – – –
30: – – – – – – – – – – – – – – – –
40: – – – – – – – – – – – – – – – –
50: – – – – – – – – – – – – – – – –
60: – – – – – – – – – – – – – – – –
70: – – – – – – – –
