IMU or Wheel Encoders for GoPiGo3 Heading Estimation
TL;DR:
Wheel Encoders were 85% to 300% more accurate than IMU
Wheel Encoder Heading Estimation displayed 33% less drift than IMU
Disclaimer: YMMV - Just documenting my observations.
Test of IMU “Heading Estimation” vs Wheel Encoder “Heading Estimation” (by integrated rotations) after four “Undock - Dock” sequences:
Conditions:
- 33 Hour test with 28 heading-affecting events:
- Undock = Drive off dock, continued forward drive till 214 mm
- Dock = two 180 turns, alignment correction, backing 200 mm, back onto dock, depth assurance)
- IMU in IMUPLUS mode (Fusion using Gyros and Accels only - no mags)
- Calibrated Wheel Dia. and Wheel Base Width to maximize turn (and distance)
command accuracy and encoder values accuracy. - All turns and driving executed at set_speed of 150dps
- CCW errors/drift are negative. CW errors are positive values.
Results
Heading Estimation Drift
– Both exhibited CCW heading estimate drift
– IMU -8 degrees total
– Wheel Encoders -6 degrees total -
For 180 degree turns:
– IMU exhibited -2.5 to +0.1 degree error
– Wheel Encoders exhibited -1.5 to -0.1 degree error -
For Undocking
– IMU average heading error was +0.6 deg,
– Wheel Encoder average heading error was -0.2 degrees
For Docking, (Two 180 turns, plus physical alignment deflectors, plus wheel slip backing assurance)
– IMU average error was -2.6 deg,
– Wheel Encoder ave error was -1.2
For Undock-Dock pairs:
– IMU -4 to +2 degree error averaging -2 degree
– Wheel Encoders -1.5 to +1 degree error averaging -1.5 degree -
Across All Events:
– IMU Heading differed from Wheel Encoder “Heading” by -3 to +1 degrees
– IMU Rotation differed from Wheel Encoder Rotation by -2.5 to +1.3 degrees
Noted:
- Prior Investigation showed NDOF mode significantly worse than IMUPLUS mode
- Bosch: “Move IMU away from power wires, encoder magnets, and motors”
- Bosch: “Use two BNO055 devices, one in NDOF and one in IMUPLUS”
On Dock (Heading 0 degrees):
UnDocked:
2020-05-10
21:56 On Dock - IMU in IMUPLUS mode, reset. IMU: 0.0 Visual: 0
23:51 UnDocked- IMU: 1.5 Visual: 0 Error: +1.5 Drift: +1.5 WEncHead: 0.8 WEncErr: +1 WEncDrift: +1
05-11 06:01 On Dock - IMU: 358.1 Visual: +0 Error: -2 Drift: -3.5 WEncHead: 359.7 WEncErr: -1 WEncDrift: -2
08:51 UnDocked- IMU: 0.0 Visual: 2 Error: -2 Drift: 0 WEncHead: 0.3 WEncErr: -2 WEncDrift: -1
15:02 On Dock - IMU: 354.8 Visual: 359 Error: -4 Drift: -2 WEncHead: 356.6 WEncErr: -2 WEncDrift: 0
17:46 UnDocked- IMU: 355.7 Visual: 0 Error: -4 Drift: 0 WEncHead: 357.2 WEncErr: -3 WEncDrift: -1
23:58 On Dock - IMU: 352.7 Visual: -0 Error: -7 Drift: -3 WEncHead: 355.2 WEncErr: -4 WEncDrift: -1
05-12 02:37 UnDocked- IMU: 353.9 Visual: 0 Error: -6 Drift: +1 WEncHead: 355.2 WEncErr: -4 WEncDrift: 0
08:47 On Dock - IMU: 351.6 Visual: -0 Error: -8 Drift: -2 WEncHead: 353.8 WEncErr: -5.5 WEncDrift: -1.5
11:30 UnDocked- IMU: 353.4 Visual: 0 Error: -7 Drift: +1 WEncHead: 354.4 WEncErr: -5.5 WEncDrift: 0
17:42 Docked - IMU: 348.8 Visual: -3 Error: -8 Drift: -1 WEncHead: 350.7 WEncErr: -6 WEncDrift: -0.5
=== imu.log ====
2020-05-10 21:56|[logIMU.py.main]** resetIMU docked - visually 0 degrees **
2020-05-10 23:51|[imulog.py.logMotionStop]heading: 1.5 rotation: 1.7 motion: 2.8 sec errors: 567
2020-05-11 06:00|[imulog.py.logMotionStop]heading: 179.4 rotation: 177.9 motion: 2.4 sec errors: 593
2020-05-11 06:00|[imulog.py.logMotionStop]heading: 179.5 rotation: 0.1 motion: 0.1 sec errors: 593
2020-05-11 06:00|[imulog.py.logMotionStop]heading: 358.4 rotation: 178.8 motion: 2.4 sec errors: 593
2020-05-11 06:01|[imulog.py.logMotionStop]heading: 358.0 rotation: -0.7 motion: 2.7 sec errors: 593
2020-05-11 06:01|[imulog.py.logMotionStop]heading: 358.0 rotation: 0.0 motion: 0.3 sec errors: 593
2020-05-11 06:01|[imulog.py.logMotionStop]heading: 358.0 rotation: 0.0 motion: 0.1 sec errors: 593
2020-05-11 06:01|[imulog.py.logMotionStop]heading: 358.1 rotation: 0.1 motion: 0.4 sec errors: 593
2020-05-11 08:51|[imulog.py.logMotionStop]heading: 0.0 rotation: 1.9 motion: 2.8 sec errors: 605
2020-05-11 15:01|[imulog.py.logMotionStop]heading: 178.5 rotation: 178.5 motion: 2.4 sec errors: 630
2020-05-11 15:02|[imulog.py.logMotionStop]heading: 358.3 rotation: 179.6 motion: 2.3 sec errors: 630
2020-05-11 15:02|[imulog.py.logMotionStop]heading: 354.6 rotation: -3.9 motion: 2.7 sec errors: 630
2020-05-11 15:02|[imulog.py.logMotionStop]heading: 354.6 rotation: 0.0 motion: 0.3 sec errors: 630
2020-05-11 15:02|[imulog.py.logMotionStop]heading: 354.8 rotation: 0.1 motion: 0.4 sec errors: 630
2020-05-11 16:11|[imulog.py.logMotionStop]heading: 354.8 rotation: 0.1 motion: 0.1 sec errors: 636
2020-05-11 17:46|[imulog.py.logMotionStop]heading: 355.7 rotation: 0.9 motion: 2.7 sec errors: 642
2020-05-11 23:58|[imulog.py.logMotionStop]heading: 174.1 rotation: 178.4 motion: 2.4 sec errors: 676
2020-05-11 23:58|[imulog.py.logMotionStop]heading: 353.4 rotation: 178.9 motion: 2.3 sec errors: 676
2020-05-11 23:58|[imulog.py.logMotionStop]heading: 352.4 rotation: -1.0 motion: 2.7 sec errors: 676
2020-05-11 23:58|[imulog.py.logMotionStop]heading: 352.6 rotation: 0.1 motion: 0.3 sec errors: 676
2020-05-11 23:58|[imulog.py.logMotionStop]heading: 352.7 rotation: 0.1 motion: 0.6 sec errors: 676
2020-05-12 02:37|[imulog.py.logMotionStop]heading: 353.9 rotation: 1.2 motion: 2.8 sec errors: 690
2020-05-12 08:46|[imulog.py.logMotionStop]heading: 171.9 rotation: 178.0 motion: 2.4 sec errors: 724
2020-05-12 08:47|[imulog.py.logMotionStop]heading: 351.5 rotation: 179.6 motion: 2.4 sec errors: 724
2020-05-12 08:47|[imulog.py.logMotionStop]heading: 351.7 rotation: 0.2 motion: 2.7 sec errors: 725
2020-05-12 08:47|[imulog.py.logMotionStop]heading: 351.6 rotation: -0.1 motion: 0.3 sec errors: 725
2020-05-12 08:47|[imulog.py.logMotionStop]heading: 351.6 rotation: 0.0 motion: 0.4 sec errors: 725
2020-05-12 11:30|[imulog.py.logMotionStop]heading: 353.4 rotation: 1.8 motion: 2.8 sec errors: 737
2020-05-12 17:41|[imulog.py.logMotionStop]heading: 170.4 rotation: 178.6 motion: 2.4 sec errors: 773
2020-05-12 17:42|[imulog.py.logMotionStop]heading: 350.8 rotation: 180.4 motion: 2.4 sec errors: 773
2020-05-12 17:42|[imulog.py.logMotionStop]heading: 348.8 rotation: -2.0 motion: 2.7 sec errors: 774
2020-05-12 17:42|[imulog.py.logMotionStop]heading: 348.8 rotation: 0.0 motion: 0.3 sec errors: 774
2020-05-12 17:42|[imulog.py.logMotionStop]heading: 348.8 rotation: 0.0 motion: 0.4 sec errors: 774
=== wheel.log ===
2020-05-10 23:51|[wheellog.py.logMotionStop]travel: 214.7 rotation: 0.8 motion: 2.8 sec
2020-05-11 06:00|[wheellog.py.logMotionStop]travel: 0.8 rotation: 178.7 motion: 2.3 sec
2020-05-11 06:00|[wheellog.py.logMotionStop]travel: 0.0 rotation: 0.0 motion: 0.1 sec
2020-05-11 06:00|[wheellog.py.logMotionStop]travel: 0.3 rotation: 179.9 motion: 2.4 sec
2020-05-11 06:01|[wheellog.py.logMotionStop]travel: -206.6 rotation: -0.6 motion: 2.7 sec
2020-05-11 06:01|[wheellog.py.logMotionStop]travel: -5.0 rotation: 0.6 motion: 0.3 sec
2020-05-11 06:01|[wheellog.py.logMotionStop]travel: 0.0 rotation: 0.0 motion: 0.1 sec
2020-05-11 06:01|[wheellog.py.logMotionStop]travel: -9.8 rotation: 0.3 motion: 0.4 sec
2020-05-11 08:51|[wheellog.py.logMotionStop]travel: 215.0 rotation: 0.6 motion: 2.8 sec
2020-05-11 15:01|[wheellog.py.logMotionStop]travel: 0.0 rotation: 179.6 motion: 2.4 sec
2020-05-11 15:02|[wheellog.py.logMotionStop]travel: 0.3 rotation: 178.7 motion: 2.3 sec
2020-05-11 15:02|[wheellog.py.logMotionStop]travel: -215.3 rotation: -1.4 motion: 2.8 sec
2020-05-11 15:02|[wheellog.py.logMotionStop]travel: -6.7 rotation: 0.0 motion: 0.4 sec
2020-05-11 15:02|[wheellog.py.logMotionStop]travel: -10.1 rotation: -0.6 motion: 0.4 sec
2020-05-11 16:11|[wheellog.py.logMotionStop]travel: 0.0 rotation: 0.0 motion: 0.2 sec
2020-05-11 17:46|[wheellog.py.logMotionStop]travel: 215.0 rotation: 0.6 motion: 2.8 sec
2020-05-11 23:58|[wheellog.py.logMotionStop]travel: 0.0 rotation: 179.0 motion: 2.4 sec
2020-05-11 23:58|[wheellog.py.logMotionStop]travel: 0.0 rotation: 179.6 motion: 2.3 sec
2020-05-11 23:58|[wheellog.py.logMotionStop]travel: -208.0 rotation: -0.3 motion: 2.7 sec
2020-05-11 23:58|[wheellog.py.logMotionStop]travel: -6.7 rotation: -0.6 motion: 0.3 sec
2020-05-11 23:58|[wheellog.py.logMotionStop]travel: -8.7 rotation: 0.3 motion: 0.4 sec
2020-05-11 23:58|[wheellog.py.logMotionStop]travel: 0.0 rotation: 0.0 motion: 0.1 sec
2020-05-12 02:37|[wheellog.py.logMotionStop]travel: 214.5 rotation: 0.6 motion: 2.7 sec
2020-05-12 08:46|[wheellog.py.logMotionStop]travel: 0.3 rotation: 179.3 motion: 2.4 sec
2020-05-12 08:47|[wheellog.py.logMotionStop]travel: 0.6 rotation: 179.0 motion: 2.3 sec
2020-05-12 08:47|[wheellog.py.logMotionStop]travel: -210.3 rotation: -0.3 motion: 2.7 sec
2020-05-12 08:47|[wheellog.py.logMotionStop]travel: -6.7 rotation: 0.6 motion: 0.4 sec
2020-05-12 08:47|[wheellog.py.logMotionStop]travel: -8.4 rotation: -0.6 motion: 0.4 sec
2020-05-12 11:30|[wheellog.py.logMotionStop]travel: 213.9 rotation: 0.6 motion: 2.8 sec
2020-05-12 17:41|[wheellog.py.logMotionStop]travel: 0.3 rotation: 179.3 motion: 2.4 sec
2020-05-12 17:42|[wheellog.py.logMotionStop]travel: 0.6 rotation: 177.3 motion: 2.3 sec
2020-05-12 17:42|[wheellog.py.logMotionStop]travel: -208.3 rotation: -0.6 motion: 2.8 sec
2020-05-12 17:42|[wheellog.py.logMotionStop]travel: -5.9 rotation: 0.3 motion: 0.3 sec
2020-05-12 17:42|[wheellog.py.logMotionStop]travel: -10.1 rotation: 0.0 motion: 0.4 sec
