Greetings!
I would like to know if it is possible to purchase the rolling-ball caster and the mounting hardware for it as a separate item? If not, where’s a good source to buy it from?
Jim “JR”
Greetings!
Jim “JR”
Personally, I much prefer the Pololu plastic ball caster  but DI does offer a replacement body kit with the ball and all hardware - (ignore the paragraph about the electronic board.)
https://shop.dexterindustries.com/shop/sensors-accessories/replacement-parts/gopigo3-clear-acrylic-body-replacement-parts
I noticed that, but I don’t need the entire kit. . . . Then again, having a set of spare parts maybe isn’t such a bad idea?
I have a micro-bot that comes with a plastic nub as its rear caster which makes it virtually useless on anything but a billiard-table flat surface covered with linoleum.
p.s. I just ordered two giggle-bots for the granddaughters to play with using their micro:bits.
Jim “JR”
Are those the new “updated” giglebot with reversable connector?
Darned if I know.
I would hope that they’re shipping the latest rev, but I honestly don’t know.
I also made a point of ordering two sets of distance sensors, servos, and sensor mounts. I suspect that one of the things they’ll want the 'bot to do is lift the pen off the paper - and when they do. . . . I’ll show them the servos and let them figure out how to do it.
Jim “JR”
Do you know which of the Pololu casters corresponds to the existing Dexter casters?
I think it is this one, (Robotshop)
the size and weight match the one I took off my bot.
I replaced mine with the Pololu 1" Plastic “Old Version” because the DI metal ball was leaving marks on my wood floors:
Here is the post about my conversion to the lighter, better, pololu caster:
Indeed we are shipping the new gigglebot now. I hope you like the changes!
