I’m trying to understand the technical architecture of the gopigo3. THere’s a Raspi and a GpG3 board. What software is on each one? Or does the GpG3 board itself have no software on it? Is there an explanation of this somewhere?
There is no official “theory of operation” doc. This is what I have gathered from the schematic, the gopigo3.py and using Raspbian For Robots.
- The GoPiGo3 hardware board contains an ATMEL SAMC20J processor
- The ATMEL firmware is proprietary and no firmware documentation is released
- The GoPiGo3 board receives commands from and returns data to the Raspberry Pi via SPI interface
- The command set is enumerated in the SPI_MESSAGE_TYPE in gopigo3.py
- The GoPiGo3 firmware monitors battery level, manages servo PWM, motor PID control, encoders
- The GoPiGo3 board firmware manages the programmable “Grove” connectors
- A2D is 12-bit with 2.048v ± 0.041v Vref
- Analog Input on pin A or B
- Digital Input or Output on pin A or B
- Software I2C clock and data
- The Raspberry Pi based user software and Dexter software
- Dexter software consists of
- a large library of drivers / examples for 3rd party “Grove” Analog, Digital, and I2C based sensors
- drivers and examples for Dexter Industries sensors
- VL53L0X I2C Time Of Flight Distance Sensor
- BNO055 Inertial Measurement Sensor (Software I2C for clock stretching that RPi does not)
- Temp/Humidity/Pressure Sensor, light color sensor, line follower, …
- Phenomenal robot examples (/home/pi/Dexter/GoPiGo3/Projects)
- Raspbian For Robots (Supports several DI products. Only listing GoPiGo3 stuff)
- service providing landing page to desktop and web based command shell
- power button handler (/home/pi/Dexter/GoPiGo3/install/gpg3_power.sh)
- GoPiGo3 Custom Desktop widgets
- Software Update
- Shutdown
- GoPiGo3 Control Panel
- Line Follower Calibration
- Scratch For Robots
- Advanced Communications applet
- GoPiGo3 Folder shortcut to docs, all software
- Version applet lists Raspbian For Robots version
- Test and Troubleshoot Applet
- Services
- Customized Apache server
- noVNC (in stretch version - I think real VNC in the buster version)
- antenna_wifi.service to manage the multi-color WiFi LED
The schematic (and all software) is on github:
Processor Family Data:
https://www.microchip.com/design-centers/32-bit/sam-32-bit-mcus/sam-c-mcus
The RPi GPIO pin usage:
