I may have a similar problem as Pingneer. My Touch and Ultrasonic sensor tests worked fine but can’t get the motor tests to run my motors. I’ve tested 2 motors and can’t get either to work. After enabling DEBUG mode I see the following output from the motor test.
So if you’re able to successfully run a sensor example or two, and not able to run a motor example, it may be a hardware problem. Just to verify one more thing: have you run the motor example? I’m assuming in Python?
Ok, sounds like it’s the motor chip then. Can you send us a message through our contact page : dexterindustries.com/contact.html and we’ll arrange a replacement.
