Motor positioning not working
I am trying to set the motor to an absolute position. I tried this in Python and Scratch with the same result:
The motor turns to the desired position but then starts doing micro movements which never or seldom stop. Is this an error or is there a workaround?
Regards,
Konstantin
I can only speak about the C++ API, but as to this, this behaviour is normal. IIUC, the BP3 motor API has PD controllers which approximate the target and then keep active continuously to track the target further on, and even correct the motor position if the motor axle is moved manually in between.
To stop the PD regulation, just add a “stop” command after the target has been reached (either by an active brake or just coasting then).
HTH!
