I am using the Official Dex card. I ran through all the update process, but if I use the VNC controller from the Dex webpage, none of the keyboard or mouse functions work. I can step through the icons using the arrow keys but can select or type and icons. Does not seem to recognise the keyboard or mouse input. Here is the result from the test_all.sh. Also running the Blink test script does not work. Nothing happens with the LED.
pi@dex:~/Desktop/GrovePi/Troubleshooting $ sudo ./all_tests.sh
GrovePi Troubleshooting Script
Adding permissions to the scripts
Check space left
/dev/root 7.2G 3.1G 3.9G 45% /
devtmpfs 426M 0 426M 0% /dev
tmpfs 430M 0 430M 0% /dev/shm
tmpfs 430M 6.2M 424M 2% /run
tmpfs 430M 0 430M 0% /sys/fs/cgroup
/dev/mmcblk0p1 63M 22M 42M 34% /boot
tmpfs 86M 0 86M 0% /run/user/1000
Check for dependencies
git 1:2.1.4-2.1+deb8u4 install ok installed
arduino 2:1.6.0 install ok installed
minicom 2.7-1+deb8u1 install ok installed
wiringPi Found
wiringPi Found
I2C-dev already there
i2c-bcm2708 already there
spi-dev already there
Hardware revision
gpio version: 2.36
Copyright (c) 2012-2015 Gordon Henderson
Raspberry Pi Details:
* Device tree is enabled.
*--> Raspberry Pi 3 Model B Rev 1.2
* This Raspberry Pi supports user-level GPIO access.
Check the /dev folder
i2c-1
spidev0.0
spidev0.1
ttyAMA0
USB device status
Raspbian for Robots Version
Hostname
dex
Checking for Atmega chip
Copyright (c) 2000-2005 Brian Dean, http://www.bdmicro.com/
Copyright (c) 2007-2009 Joerg Wunsch
Using Port : unknown
Using Programmer : gpio
AVR Part : ATMEGA328P
Chip Erase delay : 9000 us
PAGEL : PD7
BS2 : PC2
RESET disposition : dedicated
RETRY pulse : SCK
serial program mode : yes
parallel program mode : yes
Timeout : 200
StabDelay : 100
CmdexeDelay : 25
SyncLoops : 32
ByteDelay : 0
PollIndex : 3
PollValue : 0x53
Memory Detail :
Block Poll Page Polled
Programmer Type : GPIO
avrdude: safemode: Fuses OK
avrdude done. Thank you.
Checking I2C bus for devices
Checking I2C bus 0
Checking I2C bus 1
00: -- 04 -- -- -- -- -- -- -- -- -- -- --
70: -- -- -- -- -- -- -- --
Checking for firmware version
GrovePi has firmware version: 1.2.7
Log has been saved to Desktop. Please copy it and send it by email or upload it on the forums
