About one year ago I bought the Bendobox wich have the Raspberry Pi B+.
Reading the manual it says that on the SD card Noobs is installed.
Today I built the GoPiGO and the only thing is that I have install the software.
But can I use also Noobs for the GoPiGo and what do I have to install on the SD card
I find bonjour in safari but when I press that button bonjour i get nothing.
I also tried with putty to login with raspberrypi.local but i get an error it says unknown host.
Thanks for the reply and what you wrote i did that, but whn i ping from my windows laptop wich have also wifi i ping to raspberrypi.local and i get an error that says unknows host. And my vendor in the Netherlands don’t sell preinstalled software for the GoPiGo.
I was using safari wich has an option for bonjour. But now i installed your link from the windows bonjour.
> Also, have you loaded the wifi credentials on the Raspberry Pi if you are using Wifi
I don’t think so. How can I loaded the wifi credentials ?
I was not succeed because while booting the rpi i saw some errors about the kernel and network.
So now i will burn that dexter image on my SD card and i hope things are better.
Karan, I burn the dexter image on my SD card and the desktop is looking much better.
But i have still problems with acces from ssh to the rpi with putty it says unknown host when i use ssh raspberrypi.local.
And where can i find bonjour in Windows explorer ?
If you already have access to the Pi, then can you run sudo avahi-daemon on terminal, which should report that avahi-daemon is running. Then run sudo iwconfig which should report that you are connected to wifi. After that try: ifconfig which should give the IP address of the Pi, here it is 192.168.1.8. Try using that to login via Putty and SSH. If that works too, then try raspberrypi.local with putty to connect to the Pi.
You cannot do anything with Bonjour on Windows, it just installs as a service and workis in the background.
I used an ethernetcable betwen my laptop and the pi but it gives the same error only a prompt.
and when i ping to the ipadres it give network unreachble.
My raspberry pi has a wifi dongle and i tried to connect from my laptop wich it have also wifi.
The only problem is that the rpi has the ipadres 169.254.8.167 and my laptop has 192.168.178.14.
I think that is not in the same range.
