so the basic gist of things. I’m programming in C and I went to compile my code using the method supplied but when I go to compile it the Pi tells me it doesn’t exist. Any ideas?
Can you give us a little more details, which might help us to solve your problem. Can share the the code that you are trying to run, the method you are following to compile the C code and also a screenshot of the output that you are getting.
-Shoban
