This would be for a stationary robot or for just using the pi to program and other general pi use. Will this be enough power for the brickpi, rpi2 and Lego motors and sensors?
My goal was to avoid using a battery pack as my unit would be a robot arm or similar type project with the unit attached to my tv via hdmi. I wanted to use a wall plug that could power the units motors, brickpi, and rpi2 but also use the same power supply when just working on the rpi itself.
Thanks again. I still have much to learn about power and of course do not want to fry anything. The above adapter will be ok, I am assuming it will not push through to much power when I am not using the motors?
Currently, with my other rpi2 I have a 5v 2amp and a 2.5amp adapters i use…if i use those plugged into the pi with the brickpi attached running no motors…Can i just use the pi as normal?
Sparkfun did not contact us about that before writing the tutorial. It’s great, but if you try to run too many motors off that power supply, you MAY end up damaging something. But heck man, it’s worth a try. Worst case scenario, you replace some hardware and try it again, right?
