Help!!! I am trying to finish a project for uni but unfortunaly, my Raspberry Pi 3 is not even able to detect my GrovePi? Any advice on what to do? I will be thankful forever! I attached the trouble-shoot output.
log.txt (3.1 KB)
Check space left
Dateisystem GrΓΆΓe Benutzt Verf. Verw% EingehΓ€ngt auf
/dev/root 15G 7,2G 6,5G 53% /
devtmpfs 430M 0 430M 0% /dev
tmpfs 463M 46M 417M 10% /dev/shm
tmpfs 463M 6,4M 456M 2% /run
tmpfs 5,0M 4,0K 5,0M 1% /run/lock
tmpfs 463M 0 463M 0% /sys/fs/cgroup
/dev/mmcblk0p1 253M 49M 204M 20% /boot
tmpfs 93M 4,0K 93M 1% /run/user/1000
Check for dependencies
python 2.7.16-1 install ok installed
python-pip 18.1-5+rpt1 install ok installed
git 1:2.20.1-2+deb10u3 install ok installed
libi2c-dev 4.1-1 install ok installed
python-serial 3.4-4 install ok installed
python-rpi.gpio 0.7.0-0.1~bpo10+4 install ok installed
i2c-tools 4.1-1 install ok installed
python-smbus 4.1-1 install ok installed
scratch 1.4.0.6~dfsg1-6 install ok installed
I2C still in blacklist
SPI still in blacklist
I2C-dev already there
i2c-bcm2708 already there
spi-dev already there
Hardware revision
RPI3B+ Pi 3 Model B+ v1.3
Check the /dev folder
i2c-1
spidev0.0
spidev0.1
ttyAMA0
USB device status
Bus 001 Device 005: ID 1a2c:2d23 China Resource Semico Co., Ltd
Bus 001 Device 004: ID 30fa:0300
Bus 001 Device 006: ID 0424:7800 Standard Microsystems Corp.
Bus 001 Device 003: ID 0424:2514 Standard Microsystems Corp. USB 2.0 Hub
Bus 001 Device 002: ID 0424:2514 Standard Microsystems Corp. USB 2.0 Hub
|__ Port 1: Dev 2, If 0, Class=Hub, Driver=hub/4p, 480M
|__ Port 1: Dev 3, If 0, Class=Hub, Driver=hub/3p, 480M
|__ Port 1: Dev 6, If 0, Class=Vendor Specific Class, Driver=lan78xx, 480M
|__ Port 2: Dev 4, If 0, Class=Human Interface Device, Driver=usbhid, 1.5M
|__ Port 3: Dev 5, If 0, Class=Human Interface Device, Driver=usbhid, 1.5M
|__ Port 3: Dev 5, If 1, Class=Human Interface Device, Driver=usbhid, 1.5M
Raspbian for Robots Version
cat: /home/pi/di_update/Raspbian_For_Robots/Version: Datei oder Verzeichnis nicht gefunden
Hostname
raspberrypi
Checking I2C bus for devices
Checking I2C bus 0
NOTE: it is normal for this one to fail
Error: Could not open file /dev/i2c-0' or /dev/i2c/0β: No such file or directory
Checking I2C bus 1
00: β β β β β β β β β β β β β
10: β β β β β β β β β β β β β β β β
20: β β β β β β β β β β β β β β β β
30: β β β β β β β β β β β β β β β β
40: β β β β β β β β β β β β β β β β
50: β β β β β β β β β β β β β β β β
60: β β β β β β β β β β β β β β β β
70: β β β β β β β β
Checking for firmware version
There are a few things I can recommend right away:
Are you using Raspbian Bullseye?Β That will NOT work with the Grove-Pi board.Β You should download the βlegacyβ version, (Buster) and use that.
Did you go to
sudo raspi-configand make sure that i2c and SPI are enabled?Β You might want to turn on SSH at the same time. -
Did you install the Grove drivers?Β There is a thread here that discusses just that problem.
Are you using a virtual environment?Β Donβt.Β It wonβt work.
Give those a try and let us know what happens.
@jimrh Thanks for your reply!
- I use the βlegacy versionβ
- Yes, I enabled them!
- I am not sure what that means but I will check!
- No, I donβt
Still get the same error (Could not open β/dev/i2c-0β No such file or directory)
What concerns me is that when youβre checking i2c buss 1, (sudo i2cdetect -y 1), youβre getting nothing.Β There should be devices enumerated there.
My own robot, (not a Grove board), returns data like this:
pi@GoPiGoOSTest:~ $ sudo i2cdetect -y 1
00: -- -- -- 06 -- 08 -- -- -- -- -- -- --
20: -- -- -- -- -- -- -- -- -- 29 -- -- -- -- -- --
60: -- -- -- -- -- -- -- -- UU -- -- -- -- -- -- --
70: -- -- -- -- -- -- -- --
pi@GoPiGoOSTest:~ $
Each of the numbers represents an enumerated device and the βUUβ at address 68 represents the Adafruit real-time clock bound to the kernel via a device tree overlay.
As you can see, there should be something there if the board is active and i2c is enabled and active.
Do a forum search for βGroveβ and look for later posts.
have you removed and re-mated the Grove from/to the RPi checking for any bent pins?
That is not an error - or perhaps call it an expected error for Bus 0 which is no longer used. Ignore it.
Issue is you are not seeing I2C Bus 1 devices. This is likely i2c not enabled, or mechanical pin issue, a failed (read-only) SDcard, or bad board.
