When I saw that a process “mysqld” was using 0% of the processor but stealing 5.5% (45MB) of Carl’s memory with 30 dormant database endpoints, I just had to introduce myself to this silent marauder.
It turns out that ModRobotics / Dexter Industries included the MariaDB fork of MySQL in the Oct 17, 2020 beta of Raspbian For Robots, which Carl is currently running. @cleoqc stated there are some projects which use the DB. I could not find them, so I created my own
(Re) Introduction to Using an SQL Database From Python
To Bring Down To Your GoPiGo
wget https://github.com/slowrunner/Carl/raw/master/Examples/MariaDB/MariaDBdemo.tgz
tar -xzvf MariaDBdemo.tgz
Using MariaDB on Raspbian For Robots
(MariaDB is an open-source fork of MySQL at purchase by Oracle.)
=== Check MariaDB is Running ===
$ systemctl status mariadb
=== Show who is using MariaDB ===
$ sudo mysql -u root -e 'show processlist'
- InnoDB is the storage engine for the MySQL / MariaDB dbms (data base management system.
(provides ACID-compliant transaction features along with foreign key support).
=== Add Python3 Interface To MariaDB
pip3 install mariadb
=== List MariaDB users ===
./test_list_users.py
test_list_user.py
Executing list_users.sql
Existing Users
User
root
Done
=== Create pi user for MariaDB
./test_add_user.py
test_add_user.py
User to add: pi
Password for pi: pipassword
Create user: pi with pw: pipassword? y
Executing add_user.sql
Existing Users
User
root
Create User
User
pi
root
Grants for pi@localhost
GRANT ALL PRIVILEGES ON *.* TO `pi`@`localhost` IDENTIFIED BY PASSWORD '*123456'
Done
Writing pw into mariadb.key.new
Rename without .new to use it
Done
=== To drop a user from MariaDB
(If you drop pi user, you must create pi user again!) (DO NOT DROP root USER!)
$ ./test_drop_user.py
test_drop_user.py
User to drop: pi
Drop user: pi? y
Executing drop_user.sql
Existing Users
User
pi
root
Droping User If Exists
User List Now
User
root
Done
=== Rename password key file for use ===
$ mv mariadb.key.new mariadb.key
=== Test Connection to MariaDB for pi user with pw in key file
$ ./test_connection.py
Connect - User: pi PW: pipassword Host: 127.0.0.1 Port: 3306 DB:
Connection successful
Closing Connection
Connection closed
Done Test
=== Test Dropping Sensor Readings Database ===
$ ./test_drop_db.py
Connect - User: pi PW: **** Host: 127.0.0.1 Port: 3306 DB:
Listing Databases
('information_schema',)
('mysql',)
('performance_schema',)
Dropping DB carldb
Error dropping DB carldb: Can't drop database 'carldb'; database doesn't exist
Listing Databases
('mysql',)
Closing Connection
Connection closed
Done Test
=== Test Creating Sensor Readings Database ===
$ ./test_create_db.py
Creating DB carldb
Listing Databases
('carldb',)
('mysql',)
Closing Connection
Connection closed
Done Test
=== Test Dropping Sensor Readings Table from carldb Database ===
./test_table_drop.py
Connect - User: pi PW: **** Host: 127.0.0.1 Port: 3306 DB: carldb
Error connecting to MariaDB carldb: Unknown database 'carldb'
=== Test Creating Sensor Readings Table in carldb Database ===
$ ./test_table_create.py
Creating sensor_data table
Query:
CREATE TABLE IF NOT EXISTS sensor_data (
id INT PRIMARY KEY AUTO_INCREMENT,
sensor_name VARCHAR(25),
sensor_value VARCHAR(10),
sensor_units VARCHAR(15),
sensor_dt TIMESTAMP
) ENGINE=InnoDB;
Query Success
Listing Tables
sensor_data
Closing Connection
Connection closed
Done Test
=== Test Adding Data to Table ===
$ ./test_data_add.py
sensor_name? distance
sensor_reading? 21.2
sensor_units? mm
add the sensor reading
Insert Success
retrieve sensor reading
(1, 'distance', '21.2', 'mm', datetime.datetime(2021, 1, 27, 12, 35, 17))
Commit Change? y
Closing Connection
Connection closed
Done Test
NOTE: Suggest add two more records for demonstration:
- light 120 (0-255)
- distance 3000 mm
=== Test Listing Data in carldb.sensor_data ===
$ ./test_data_list.py
Retrieve sensor reading
Query:
SELECT * FROM sensor_data
Closing Connection
Connection closed
Done Test
=== Test using WHERE to extract only one sensor’s reading(s)
$ ./test_data_where.py
Connect - User: pi PW: **** Host: 127.0.0.1 Port: 3306 DB: carldb Connection successful
First Listing All Rows
1 - distance: 21.2 mm at 21-01-27 12:35:17
2 - light: 120 0-255 at 21-01-27 12:43:51
Now Only Readings For One Type Of Sensor
Retrieve distance sensor reading(s) Query:
SELECT sensor_name, sensor_value, sensor_units, sensor_dt FROM sensor_data WHERE sensor_name=? ('distance',) Returns Rows: ('distance', '21.2', 'mm', datetime.datetime(2021, 1, 27, 12, 35, 17))
Retrieve sensor readings not using fetchall() distance 21.2 mm at 2021-01-27 12:35:17
Closing Connection Connection closed Done Test
=== Test Update Latest Record Of A Sensor ===
Example changing last distance reading from 3000 mm to 200 mm:
$ ./test_update_last.py
Executing test_update_last.py
(2, 'light', '120', '0-255', datetime.datetime(2021, 1, 27, 12, 43, 51))
(3, 'distance', '3000', 'mm', datetime.datetime(2021, 1, 28, 7, 31, 48))
Reading To Update
New sensor_reading? 200
New sensor_units? mm
Updating the sensor reading and units
Update Attempted
(3, 'distance', '200', 'mm', datetime.datetime(2021, 1, 28, 7, 42, 12))
Commit Change? y
Closing Connection
Connection closed
Done Test
=== Test Dropping Specific Row ====
$ ./test_row_drop.py
(2, 'light', '124', '(0-255)', datetime.datetime(2021, 1, 28, 7, 42, 51))
Row To Drop
id? 1
Dropping row 1
Executing Query:
DELETE FROM carldb.sensor_data
WHERE id=?
Drop Attempted
Commit Change? y
Closing Connection
Connection closed
Done Test
=== TO STOP MARIADB FROM STARTING AT BOOT ====
$ sudo systemctl stop mariadb
$ sudo systemctl disable mariadb
Removed /etc/systemd/system/multi-user.target.wants/mariadb.service.
Removed /etc/systemd/system/mysqld.service.
Removed /etc/systemd/system/mysql.service.
NOTE: to see it is still there
$ systemctl list-unit-files | grep mariadb
mariadb.service disabled
mariadb@.service disabled
=== TO RE-ENABLE MARIADB TO START AT BOOT ===
$ sudo systemctl enable mariadb
$ sudo systemctl start mariadb
